removing window tints?
Old Jan 1, 2010 | 06:36 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default removing window tints?
Buying another octavia vrs on sunday and its got full tints all sides and rear screen,just wondering how hard and the best way to remove?
Also removing it from rear screen will it damage the heated screen elements?
cheers lee
Old Jan 1, 2010 | 06:40 PM
ha ha what are you like. Not another car. Is the saff still going ok mate.
Old Jan 1, 2010 | 06:41 PM
jacko's Avatar
jacko
stanly blade and a heat gun
Old Jan 1, 2010 | 06:44 PM
jaiscossie's Avatar
jaiscossie
The heated rear screen should be fine if your carefull.Peel off the film on the inside first.Easier on a warm day as its not brittle (or get the car nice and warm inside first) Then with the layer left underneath either thinners carefully or t&g remover will get the glue off with a blade.
Old Jan 1, 2010 | 06:51 PM
dakar's Avatar
dakar
I want my vrs with tints
Old Jan 1, 2010 | 06:58 PM
furqall's Avatar
furqall
do not use a blade anywhere near the rear heating element , use a heatgun to warm the tint on the heated rear them pull the tint of slowly. You will probably have glue residue still on the window so get some soapy water in a spray bottle and spray the window the glue should turn white ish then use very fine wirewool to remove the glue .
if you use thinners you can end up spreading the glue all over the place.
for the side windows use a heatgun to warm the tint peel the tint off, spray the glue residue with soapy water then use a single edge blade the ones with the alumium strip (not a stanley blade) to gently remove the glue
Old Jan 1, 2010 | 07:17 PM
Dicko&Vacant
cheers fellas ill have a go when we get it
Glenn the cossie is going sound mate
Old Jan 1, 2010 | 08:25 PM
Nice one bud for a minute there i thought you were gonna say the skoda was gonna take the cossies place.
Old Jan 1, 2010 | 08:35 PM
Dicko&Vacant
dont be so daft.... its Sarahs car
Old Jan 1, 2010 | 08:48 PM
studabear's Avatar
studabear
Tell the seller you will only buy with the tints removed, simples
Old Jan 4, 2010 | 06:55 PM
Dicko&Vacant
right ive got the tint off, but left a horrible sticky glue residue, any ideas how to get it off??
Old Jan 4, 2010 | 07:16 PM
cossiejsy's Avatar
cossiejsy
panel wipe if not try wet wipes or turps
Old Jan 4, 2010 | 07:41 PM
**caz**'s Avatar
**caz**
there is a "adhesive remover" in a blue bottle that is excellent for removing residue left from stickers/tints! ill see if i can find out the make for ya....
ok i cant find it lol but ya local motor factors will have it, its only a few quid but it does the job!
x
Old Jan 4, 2010 | 07:48 PM
Mrs T's Avatar
Mrs T
Super Moderator
i watched how clean is your home yesterday and they removed sticker residue with wd40 would that be the same sort thing for tints?
Old Jan 4, 2010 | 07:50 PM
The Youth.'s Avatar
The Youth.
thinners and it will walk off
steve
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
