Who all uses pressure washers/snow foam ?
Old Jan 1, 2010 | 02:41 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Who all uses pressure washers/snow foam ?
Whay ya got and where from ??
Old Jan 1, 2010 | 03:02 PM
cozzy jeff's Avatar
cozzy jeff
http://www.cleanyourcar.co.uk/washin.../prod_371.html
http://www.cleanyourcar.co.uk/washin.../prod_370.html
karcher pressure washer got mine from srcewfix about 6mths ago was on special offer cost about £120
Old Jan 1, 2010 | 03:05 PM
KSA-Cossie's Avatar
KSA-Cossie
Could you use megs hyper wash for foam ?
Old Jan 1, 2010 | 03:13 PM
cozzy jeff's Avatar
cozzy jeff
yes can be diluted also
http://www.cleanyourcar.co.uk/washin.../prod_326.html
Old Jan 1, 2010 | 03:20 PM
KSA-Cossie's Avatar
KSA-Cossie
Nice one jeff,is karcher the best one to go for ?
Old Jan 1, 2010 | 04:41 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
For light home use yer. Cheap and good warranty from B&Q. Just keep taking it back every 11 months.
There are others much better though, if you want propper gear. Like Kranzle.
Prepare to spend a bit more and get less 'features' though. The actual machines are incredible, and CYC do fittings to use foam lance etc. Although most Kranzle machines can do high pressure chemical mixing so no need to swap lance ends etc. Unless you want to longer dwell time of thicker foam.
Old Jan 1, 2010 | 04:44 PM
KSA-Cossie's Avatar
KSA-Cossie
Just to wash the car at weekends.
Old Jan 1, 2010 | 04:45 PM
Gav Diamond's Avatar
Gav Diamond
For foam lance i use this one
http://www.polishedbliss.co.uk/acata...ance-wash.html
I used to have the CYC one but it fell to bits on me so replaced with the PB one and has been faultless.
Also the Polished Bliss one uses a plastic connector for the Karcher which is a much better fit as i had to file the brass one from CYC to get it to fit.
For pressure washer i have a Karcher 500 i think it is, wasn't cheap but its only just starting to show its age after 7yrs and it used alot for all sorts from washing cars, vans, a few small trucks and have done the patio and drive way a few times which will be at least 7hrs continues use in one go at a time.
Old Jan 1, 2010 | 04:51 PM
AstoN_B's Avatar
AstoN_B
Originally Posted by Gav Diamond
I use this one
Haven't used that one as i have the CYC one. Been trouble free for a year. Use it while valeting sales cars so gets used at least 3 times a week every week.
I got the brass fitting with mine, didnt fit so i rang Tim @ CYC that morning and he has an alternative to send out free, some karchers have different size lance.
Got new karcher and just swapped back to brass fitting cause it leaked with plastic one.
Old Jan 1, 2010 | 04:56 PM
yellowsierra's Avatar
yellowsierra
If like me you a Karcher then this will do the job without spending a fortune
http://cgi.ebay.co.uk/KARCHER-FOAM-L...item33587ac1a3
Old Jan 1, 2010 | 05:29 PM
AstoN_B's Avatar
AstoN_B
I believe the foam won't be as thick or good with that one. Plus the others are adjustable so can use strong mix then turn it down so it lasts longer. either way i'd get a 1litre bottle instead of the small ones they come with.
Old Jan 1, 2010 | 05:31 PM
KSA-Cossie's Avatar
KSA-Cossie
Yeah i'd be going for the litre one.
Old Jan 1, 2010 | 05:46 PM
Gav Diamond
These give the same results foam wise as the hose end sprayer
http://www.cleanyourcar.co.uk/washin.../prod_335.html
from what i have seen anyway.
Aston_B
Looking on the CYC site the lance they have now is different to the old one i had so maybe others had the same problem as me and they updated it.
Old Jan 1, 2010 | 05:50 PM
:hEnNiKeR:'s Avatar
:hEnNiKeR:
Bam Bam Bam
im a valeter and car washer, we got a mega karcher but it cost thousands and that goes wrong regulaly.
we also got two home made ones which cost around 800 each and they break too.
like has been said buy a cheap karcher with warrenty and take it back 11mths on cos there not very well made, everyone ive spoken to has gone wrong...
Old Jan 1, 2010 | 05:52 PM
GAZ345's Avatar
GAZ345
if you are looking for a pressure washer costco are doing a cracking price on this karcher http://www.halfords.com/webapp/wcs/s...egoryId_165689
£229
Old Jan 1, 2010 | 06:04 PM
Caprigirl's Avatar
Caprigirl
Drift Queen
My cleaning company replaced our old warick machine just cause it was old and tired , we bought a new karcher hds 501 , what a pile of junk , we have had them out repairing it 4 times in the first year and twice in the second year , its been nothing but bother and I wish we had just stuck with the old machine.
I would not buy another karcher machine now
Old Jan 1, 2010 | 06:23 PM
cozzy jeff's Avatar
cozzy jeff
people have there own opinion about karcher,i went for karcher because it was on spacial at the time,ive owned it for just over a year now and and use it most weekends,either cleaning the car,van or the r1 and ive had no problems with it,go for what you can afford mate,if your useing it just to wash the cossy on a weekend in my opinion you cant go wrong with a karcher.
Old Jan 1, 2010 | 06:24 PM
Csm's Avatar
Csm
Ive had loads of different machines when i was a mobile valeter
All shite and unreliable apart from my last petrol one
Cheap petrol ones just fuck up and the pumps always pack in no matter what
Honda Cobra 160, i then built a custom twin lance for soap and pressure with side ajuster and was the best i ever had, wish i never sold it now tbh
Karcher seem very cheaply made compared to many years ago
Buy a cheapy and replace it every year kev if need be
Old Jan 1, 2010 | 06:35 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
I use meguiars hyperwash for foam. 4-5 squirts in the 1 litre bottle on the lance the fill with HOT water.
Find it better to hose car down first too...
Old Jan 1, 2010 | 06:41 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
2 at once but foam a little on the thin side or had been on for a bit, can't rem.
better foam,
Old Jan 2, 2010 | 09:05 AM
AstoN_B's Avatar
AstoN_B
I can say in my experience using hot or cold water hasn't made a single difference to the foam or how it foams up/clings. And i've tried Meg's, Cheaper stuff and Valet Pro PH Neutral.
I wouldn't rinse the car first either, as this will dilute the foam and make it slide off easier and quicker, the idea of foam is it stays on for as long as possible to soak and lift the dirt away.
Unless ofcourse you have half inch of mud up side of your car, probably better to blast the bottom half then...
Old Jan 2, 2010 | 09:26 AM
KSA-Cossie's Avatar
KSA-Cossie
Thanks for that chop,what p/w are you using ?
Old Jan 2, 2010 | 11:15 AM
cozzy jeff's Avatar
cozzy jeff
i also dont see the point in topping up the lance with hot water as your using cold water through your pressure washer.everyone has there own opinion on how to wash there car,if you ask 100 people your sure to get 100 different answers.
Old Jan 2, 2010 | 11:18 AM
cozzy jeff's Avatar
cozzy jeff
look here for more advice
http://www.detailingworld.co.uk/forum/index.php
Old Jan 2, 2010 | 11:56 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Karcher mate. Cant rem which, is it the k series maybe? Just a "normal" one.
Old Jan 3, 2010 | 12:06 AM
the benno's Avatar
the benno
karcher with cyc foam gun and valet pro ph neutral foam for me
Old Jan 3, 2010 | 10:10 AM
STUCOS's Avatar
STUCOS
B@Q mac4 £249 reduced to £199 but have a 1/2 price sale so £99 got one the other day and they gave me an extra 15% for spending over £50 ,so cost under £85 ,and comes with 3 yr guarantee,get down to b@q kev
cheeRS stu
Old Jan 3, 2010 | 10:11 AM
STUCOS's Avatar
STUCOS
Here is the link,but think sale finnishes tomorrow
http://www.diy.com/diy/jsp/bq/nav.js...=mac4&x=24&y=9
kev tosh got one as well,thats how i found out
cheeRS stu
Old Jan 3, 2010 | 10:26 AM
Toe Knee's Avatar
Toe Knee
for that price cant complain but u sure bout the 3yr warrenty?!
quote off site......
MacAllister MAC4 Pressure Washer
MacAllister MAC4 Pressure Washer "Just brought the Mac 4 pressure washer after looking at all the MacAllister range Mac 1 - 4. Decided on The Mac 4 because it was designed for heavy duty use. One huge disapointment is that Mac 1 - 3 are warranted for 3 years but The Mac 4 only comes with a 1 year warranty for a product that should be superior to the others. Can not help thinking if the Mac 4 cannot handle heavy duty use for more than a year. Only 2 stars because of warranty issue. Could B & Q comment on this?"
also says in the product description 1yr warrenty not 3, but for the price cant really complain i guess!!
Ive got an old old kartcher my parents bought years ago and its still goin!! came with the foam bottle too so may have to invest in some decent cleaning foams
Old Jan 3, 2010 | 10:33 AM
KSA-Cossie's Avatar
KSA-Cossie
cheeRS stu
Will take a wee look later on.
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Dubs44
Sep 19, 2015 06:31 AM
