fuel pump / boost problem...ALL SORTED THANKS LADS
Old Dec 31, 2009 | 03:32 PM
COLEYST200's Avatar
COLEYST200
Default fuel pump / boost problem...ALL SORTED THANKS LADS
hi there lads is there any way to tell wot pump is on my 3dr
why im asking is my 3dr has a t34 on it with black 55lb injectors swedish plenum rs 500 intecooler and running only 15psi boost but when i up the boost it starts to splutter and back fire . we have set the AFR to about 12
and i have a fuel pressure gauge unber the bonnet and its at 3 bar and 3.5 bar with the vac pipe of . so im thinking it could be the pump or the wire running the pump . im going to run the fuel pressure gauge into the car and see wot it dose when the car comes on boost should it still be 3 bar ???????? and wot should the volts on the pump on tick over and on boost be showing .. thanks for any help
Old Dec 31, 2009 | 03:54 PM
LHD220Turbo's Avatar
LHD220Turbo
it best to check the volts at the pump whilst on boost, as that is where it matters most
but you can check it at idle to see what your getting, and it its obviously low at idle it will be even lower while on boost
should be seeing around 12v at idle, before i rewired mine i only had 9v at idle
Old Dec 31, 2009 | 04:01 PM
COLEYST200's Avatar
COLEYST200
thanks for that mate i will go had have a look at it as its good you can do some of it on tick over. is there any way to tell wot pump it is standerd/044 ???
Old Dec 31, 2009 | 04:04 PM
LHD220Turbo
what fittings are on the pump? that's normally the give away
is the pump noisy? 044 pumps are normally noisy
Old Dec 31, 2009 | 04:05 PM
Toe Knee's Avatar
Toe Knee
standard it'll have the yellow/black push on connectors but when people fit 044s they ususally cut them off and crimp on ring connectors!! also thing the terminals are blue and red from memory, also standard the pump has a moulded inlet pipe that the pipe coming from the tank goes onto whereas an 044 will be a screw in fitting!
Old Dec 31, 2009 | 04:11 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
fuel pressure should increase 1:1 with boost normally, so for every 1 psi of boost pressure the fuel pressure should raise 1 psi, this will increase on the atmospheric value which is 3.5 bar std
Old Dec 31, 2009 | 04:25 PM
COLEYST200's Avatar
COLEYST200
iv had a look at the volts at the pump and its running at 11.5 volts on tick over
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
put it on the rollers, watch the fuel pressure guage as it comes on boost....
ohh aye cant do that with live mapping
Old Dec 31, 2009 | 04:27 PM
COLEYST200's Avatar
COLEYST200
it dose not seam to be that noisy a pump but it was on the car when i got it so i dont no any thing about it
Old Dec 31, 2009 | 04:29 PM
JTECH James
Passion for Fords!
cant check fuel pressure while live mapping? really? we do all the time
check the voltage under load, static doesnt mean much tbh
Old Dec 31, 2009 | 04:30 PM
COLEYST200's Avatar
COLEYST200
thanks mate im going to try that with the pipe iv got i can put fuel pressure guage in the car and get my mate to see wot it says
Old Dec 31, 2009 | 04:31 PM
LHD220Turbo
looks like a 044 pump to me; can you take a pic of the line from the tank to the pump to make sure
to be honest i dont think you problem is fuel related; i would be looking elsewhere, have you checked the CPS and phase?
Old Dec 31, 2009 | 04:32 PM
mechanic28's Avatar
mechanic28
grp a pump it looks to me bud
Old Dec 31, 2009 | 04:33 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
What plug gaps are you running?
Old Dec 31, 2009 | 04:34 PM
vroooom ptssssh
It Wasnt Me!
Originally Posted by James @ M Developments
cant check fuel pressure while live mapping? really? wow lol we do all the time
I doubt many live mappers do..How do you check it on a 4x4 cos? bit of metal pipe inbetween the connecter down by the inner wing? And I was reffering to using his fuel pressure guage that he already has
COLSEY, What plugs are you running and what gap? My guess is irridium!
Old Dec 31, 2009 | 04:37 PM
COLEYST200's Avatar
COLEYST200
thanks mate iv just been on the phone to my mate REX and over the weekend we are going to run some wire in to the car so we can see wot is going on back there . has any one got a drawing of the wiring loom to replace the old one
and wot do you meen.... wow lol we do all the time
Old Dec 31, 2009 | 04:40 PM
JTECH James
Passion for Fords!
we have special adaptors made so pressure is tested safely as it should be
he has already stated he intends to run a gauge in car which is a good thing to check
Old Dec 31, 2009 | 04:41 PM
vroooom ptssssh
It Wasnt Me!
Great
I still believe RR mapping is the way to do it, can watch what's going on under the bonnet/hear det a lot easier...blah blah
each to there own.
Old Dec 31, 2009 | 04:43 PM
COLEYST200's Avatar
COLEYST200
right im running a wast spark set up on the car with MOTORCRAFT SUPER AGPS 071C plugs out the box and into the motor
Old Dec 31, 2009 | 04:45 PM
JTECH James
Passion for Fords!
cant drive to work on a frosty moning on the rollers either,
no better scenario for mapping than the actual conditions the car will actually be used in
we hear det just fine with the correct equipment
Old Dec 31, 2009 | 04:49 PM
JTECH James
Passion for Fords!
what chip is it on, afr of 12 is a bit lean imo, id aim mid 11s
Old Dec 31, 2009 | 04:52 PM
vroooom ptssssh
It Wasnt Me!
bin the motocraft plugs, get some NGK copper's and gap to .6 or at least gap the motocraft ones down.
So you's have cars all year round for mapping? jeez!
Less chance of killing yourself or some innocent person on the rollers tho eh you must admit?
Old Dec 31, 2009 | 04:56 PM
scoooby slayer's Avatar
scoooby slayer
its highly unlikely imo its fuel as unless its alot short it will still run but lean, and if its holding base pressure at idle and good voltage then shows pump/wiring isnt completeley fubared. its quite possibly a spark related issue.
have you got an ignition cut at over 1 bar boost in your ecu maybe ?
my car had crap voltage to the pump, constantly crap droping to base pressure at 1.5 bar boost, that still ran but getting very lean.
id definitaley be looking at ignition side aswell mate.
JTECH James
Passion for Fords!
yep all year, we can map anywhere like brunters etc if we feel the need for big power stuff, we dont take risks, its our jobs and lives we do it for a living not for a laugh
and 071c is a good plug to over 600bhp, so they wont be the problem
.6 is way to small a gap on coil pack. .75 is fine
Old Dec 31, 2009 | 05:20 PM
COLEYST200's Avatar
COLEYST200
its on a REYLAND CHIP....L6 ECU
Old Dec 31, 2009 | 05:31 PM
COLEYST200's Avatar
COLEYST200
The end of the pump is just swayze,d over when it was make like this one
Old Dec 31, 2009 | 05:40 PM
COLEYST200's Avatar
COLEYST200
Iv just had a look and the plugs and they are at .75
could it be that . Me and Martin no that the car needs to go on the rollers to set it up 100% and the chip is just a bass chip to run the stuff on the car
Old Dec 31, 2009 | 05:50 PM
carlo's Avatar
carlo
has it only done it scince you fitted the sweedish plenium? could it be some kind of surge problem?
Old Dec 31, 2009 | 06:11 PM
COLEYST200's Avatar
COLEYST200
no mate i had a play with it befor and it was the same then . And thinking about it last time i had a play with it it was on greys and a different chip
Old Dec 31, 2009 | 07:05 PM
COLEYST200's Avatar
COLEYST200
Iv been on EBAY having a look at some of the pumps on there and one thing iv see is that there are some pumps on there for ford escort rst and they have the same blue ends on them the same as is on my pump which is making me think just get a new pump off MATT lewis and be done with it as if it is one of them pump and it standerd and i wont to be running 360/380 BHP it needs to be right . but im still going to do some testing on the car over the weekend to see if i can put my finger on it
Old Dec 31, 2009 | 07:13 PM
bad boy rs's Avatar
bad boy rs
looks like a group a to me mate, how long you been using them 071's for ? i bought a set of them and threw them in the bin after 10 miles, mine was fine on stage 1 with these but soon as i stepped up to greens & t34 it was missing like fuck, changed to some champions and it was spot on
Old Dec 31, 2009 | 07:32 PM
COLEYST200's Avatar
COLEYST200
they have been in for about 8 weeks now
Old Dec 31, 2009 | 07:35 PM
bad boy rs's Avatar
bad boy rs
has it ever run good with them ?
Old Dec 31, 2009 | 07:42 PM
COLEYST200's Avatar
COLEYST200
yes mate BUT its only ever been run with 15.psi boost i did have a play with the boost about 3 months back and it did the same .and sins then the chip and injectors have been changed and plugs have been changed and iv now had a play for the second time and its doing it again
Old Dec 31, 2009 | 08:04 PM
scoooby slayer
my old saph did just the same was fine up to 18 psi above that and would just misfire. i changed fuel pump to group a, checked voltage and pressure all good.
i put it down to an ignition problem but i never did cure it just left it on 18 psi.
its not something silly like map sensor is it ? definateley got a 3 bar on there and its working ok ? your symtoms are definateley similar to hitting overboost, my old escort rs turbo did exactly the same thing if it ever saw 11 psi on standard ecu, would just misfire where i think the ecu was cutting the spark due to seeing overboost.
Old Dec 31, 2009 | 08:14 PM
COLEYST200's Avatar
COLEYST200
definateley got a 3 bar on it but its one of then things it was on the car when i got it so iv tuck it it works ok but is there any way to test it
Old Dec 31, 2009 | 09:09 PM
bad boy rs's Avatar
bad boy rs
surley if its a chip for the correct spec it isnt boost cutting ?
Old Dec 31, 2009 | 09:14 PM
COLEYST200's Avatar
COLEYST200
I dont think its the chip as it did it on the old chip to . If i cannot sort it i will just give it to martin and get him to sort it as he has all the kit to find the fault and put it right
Old Dec 31, 2009 | 09:19 PM
bad boy rs's Avatar
bad boy rs
nothing worse than having a problem like this, thing is its always something realy stupid
Old Dec 31, 2009 | 09:25 PM
COLEYST200's Avatar
COLEYST200
tell me about it matei love to sort stuff myself as it saves the £££ . wot dose my head in more do i by new parts to only find its not them . and i would like to get it right befor it gose back to martin as it will just hold it all up and cost more . its doing my head in at the mo
