Building a new race car
Thanks to Luke at Enhanced Performance for being busy over Christmas building this up. Had a few rusty holes patched up and lots of blue paint on its underside. Will be a racecar by March. Just need to put some more money into bits and pieces. Loom is done, diff, box, prop are reconned and fitted. Rear beam is on solid poly bushes and powdercoated. Gaz Gold coilovers are on. Brake master cylinders and lines are in. Engine will go in soon with small alternator, new rad and hoses, T3 turbo with restrictor. Need fuel tank, some fittings and it shouldn't be too long til we can test.
Charlie
Charlie
Wedgewood blue is a good description. I've been calling it gay sailor boy blue and biddy blue.
Charlie
Yellow shell was old, battered, had a bolt in cage and needed a lot. The new shell is a good base for a proper race car.
And yes, standard rear beam because the regulations for my series say I cannot modify the suspension pick-up points. Beam is mounted in rock hard poly mounts.
Charlie
Charlie
Charlie
What formular you racing in mate, I try and come and spectate if I know where and when and its not 200+ miles away. Nice to see fellow members giving it go, as it takes alot of time, money, dedication to race.
Charlie
Charlie
The club I race in has two series running - one is the pre-94 touring car series that I race in, the other is a production BMW series for E30s 318 and 320s. The BMWs also race in our series as well as their own.
Charlie
Charlie
looking good charlie ,
so how competitive are you in the sierra ,
cos from looking at that pic your either leading the pack ,
or you about to get lapped by everyone lol ,
beef
beef
Not very competitive in the yellow Sierra but I hope I'll be better in the blue car as it'll be better in some ways and the suspension set-up should now be about right. I still need to learn to drive properly
Charlie
come have a go in the boss fords 2nd year this year,most people that use to race in the ford saloon car championship lots of different machinary here for you to race with good crowed to try this website if intrested a follow links wealdenracing.co.uk
i can vouch for that its the new series that took over from the ford saloons this will be there second season,good series and a great crowd to race and socialize with,i cant wait to get back out when my cars finally done, def checkout wealden racing .co.uk loads of info about the boss series
got some bells mate thanx see ya soon
ash
How much are the race fees? I'm committed to TTRS this year but always interested in a new series. I guess if it's through the CTCRC it'll be expensive.
Charlie
saw you at brands last year with the dtms, was all excited seeing the saph and there was two black three doors, think you might have had some probs as you disapeared quite quickly?? i do remember there was an orange RX7 that looked pretty rapid??
Charlie
