MSD Chip Sapph Cosworth (L8) *New Price*
Hi,
Im Selling my L8 Evolution Chip to suit a standard Cosworth yb with T3 Turbocharger, Bosch 803's, 3 Bar Map Sensor, Large Intercooler, Exhaust System.
With Anti Lag & Launch Control Built In.
Come With All Instructions & Ill throw in my modifed Idle Control Valve For Anti Lag.
£370
07872113032
Brian
Will get a photo up later.
£370
07872113032
Brian
http://img192.imageshack.us/img192/3...c00060r.th.jpg
Evolution Chip / Now Safely Removed And In Protective Box Supplied By MSD
Also Have a Garret T3 For Sale Turbo of my 4*4 Sapphire Cosworth Was Going Well For Me But Would Advise A rebuild Before Fitting Slight leak between Comprresor housing and exhaust housing though still ran perfect on the car, just upgrading to a T34. Open to Offers on it.
cheers for sortin pics, didnt realise.
Yea silver one paul, Was up in Bangor one night a while back. lol! Havent had car out since tucked away for winter and a bita tinkering about & tidyin.
Same here lol, can't be driving in the crappy weather!
What spec are you going for now? Might interst you to know we are trying to get NMS over to do live mapping sometime early in 2010. Makes a good difference over an off the shelf chip!
Paul, just for gettin this t34.48 fired on and maby changed injectors, if chip dosent sell il just send it away and it reprogammed for new turbo and injectors, mate has a set of cosworth cams for me if i want them but funds are low mainly because of a certain money box with 4 wheels. Not sure about live map as have few others bits i wana sort out first. what sorta money does the live map cost.
Hi mate, if you are going to use a chip on your car, it may be best to just get Stu to redo your own? That way you keep the launch control etc?
you going to do some of the shows next year?
hi mate just a little qquestion for you i fitted one of these chips in my cousins saff but wouldnt start had to put original back in to getit going again do you have any ideas what would cause this thanks.
Only thing i can think off would chip have been put it wrong way? As i done it to mine just kept turnn over and over. Might be best to get the msd guys to check the chip. Must short it out if its put in the wrong way.
Karl 3dr
102
Oct 14, 2016 08:17 PM
Aug 14, 2015 07:29 AM
