S2 Turbo loom help
Hi folks
Me again
anyone in or around the wiltshire area that can help with removing a wiring loom from my s2 rs turbo
would need it removed, and then re-instated back in once my welding has been done.
any help apreciated
thanks
marc
Me again
any help apreciated
thanks
marc
it is an easy enough task to remove the loom. If possible, as you disconnect the connectors, label them so you know what they should connect back on to. i.e handbrake lever, ciggy lighter etc.
For the roof clock, tie a length of string (or 2 to be safe) onto the loom, and pull through then you should have a length of string that can be connected to the loom and pulled back up the pillar.
take your time and dont cut any wires and you will be fine.
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
