General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
My old V reg LX had electric windows, air con, heated front screen, so to be fair it wasn't short of much! The ghias had trip computer, cruise control and leather etc.
My mam has a 51 reg focus LX thats got air con heated front screen cenral locking front electric windows.I think you can fit front fogs but i cant see any wires behind the front bumper for fogs.
Oh yes, I put a collection front bumper on mine, the wires for fogs were taped up behind the front cross member, plug them in, fit a new switch and they worked!
cheers for the replys guys so you saying it would be possible or t hard to fit fogs? and i dont mind about the other stuff manily wanted the fogs for when i fit the rs kit
cheeers
I'd fit the figs and switch, and wouldn't worry too much about wiring them - it's not like they do that much on the odd occasion that the weather is bad enough to switch them on!!!
true unless you want to be one of the many idiots that drive everywhere with them on should be 3 points on the licence that way we would not be blinded by some of them
Do you not have to fit a relax. Do the fog lights just screw to the back of the bumper. My dad wants some for his focus.
Nope the relay was already there If its a pre facelift you screw the fogs in to your original bumper and fit the smaller bumper grille, if its post facelift, pull out the plastic blanks and push the new fogs in. Its easy peasy!
the focus is a 51 reg with the indicators in the head lights. So the fog lights just click in. Where did you say the wires were. Ive had the car on a ramp and i couldnt see the wires behind the front bumper around the radiator.
You might need to take the front bumper off to find them as they are well tucked away but will be there. Bumper comes off easy enough, couple of screws in the arch then unclip it across the front, 5 mins and its off
bonus i might have a word with my dad and i might pop to the scrapy and get all the gear. I fitted front fogs similar to this to my old sierra. I plugged the switch in fitted the relay and found the wire for the lights.
Had a look at my dads car today and im sure r found the wires. I had a look in the fuse box to see if i could see a fuse and a relay for the front fogs.
If its a CL model then you will need to change the central locking module that is next to the steering column under the dash to one that is a remote module. Then program the key to the car as per instructions in your handbook and it will work.
If it higher than a CL model, then it should have a remote?
An LX should have remote locking. At least my old V plate LX did, and the only ones I have seen without remote locking are the bottom of the range CL models.
They have had the car for over 6 years and they have only ever had the 2 keys for it. I could always put it on my ford tester at work and see if there are more than the 2 keys coded in
