Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
water leak in 2005 ka
Old Dec 26, 2009 | 04:29 PM
stet65's Avatar
stet65
Angry water leak in 2005 ka
hello, I have water ungress thru' both doors, collecting at the side of the seat in the floor where the chassis id plate is. this can only be coming past the door seals and dropping down. is this possible or common? can't believe I need to replace boot door seals in a 2005 car. Any one had similar experience, or can you suggest any other cause??
Thanks
Old Dec 26, 2009 | 04:32 PM
stet65's Avatar
stet65
I should add that this water has collected while the car has been standing for a couple of weeks.
Old Dec 27, 2009 | 11:10 PM
dug112y's Avatar
dug112y
passionford pro
take the seats carpet and dash out then get a mate to run a hose over it while you sit inside looking for where water is running in....only way to find it properly .seal it up and rebuild.
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
Sp3no
Sep 27, 2015 07:23 PM
