ST170 Engin light on
Old Dec 26, 2009 | 01:53 PM
Pieter Erasmus's Avatar
Pieter Erasmus
St 170 Owner @ 330 000 km
Default ST170 Engin light on
ST170 - How do I switch off the engin light if I remove the catalytic convertor? (make it blind to the Engin Management System) I was led to believe that the Cat only lasts 160 000km, My ST has done 295 000 to date.
Old Dec 26, 2009 | 02:57 PM
im sure you cant do it mate. Does your car have a lambda sensor in front of the cat and a lambda sensor behind the cat.
Old Dec 26, 2009 | 06:29 PM
Pieter Erasmus
According to the dealer its got a Pre and Post Catalyst Oxygen sensors, one before and one after the Cat...
Old Dec 26, 2009 | 07:17 PM
Well if you have took the cat out the lambda sensor after the cat picks up exhausts arnt right so tells the ecu and brings the light on.
Old Dec 26, 2009 | 07:30 PM
Pieter Erasmus
Any knowledge on how to "lie" to the ECU to make the light go away? If I can locate the spec for the ranges for the ECU input - I can rig up a resister that would do the trick.
Old Dec 26, 2009 | 07:39 PM
~nomad~'s Avatar
~nomad~
the only way is to take the bulb iirc. the lamba sensors have to be present and reading right.
Old Dec 26, 2009 | 07:45 PM
Correct.
Modern cars you cant do anything to them nowa days.
Old Dec 26, 2009 | 07:56 PM
Pieter Erasmus
Correct.
So, I'll have to replace the Lamda sensor again I guess, thanks for the replies.
Old Dec 26, 2009 | 11:23 PM
simon170's Avatar
simon170
http://www.teamtorquesteer.co.uk/fie...liminator.html
Old Dec 29, 2009 | 09:14 PM
Pieter Erasmus
Thanks Simon,
Thought someting like this must exist!
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
Old ford
Jul 31, 2015 06:50 AM
