2wd cosworth breaking, engine, bb big turbo, external wg, bd14, adjustable suspens
Old Dec 25, 2009 | 08:34 PM
Mj_stakis's Avatar
Mj_stakis
Default 2wd cosworth breaking, engine, bb big turbo, external wg, bd14, adjustable suspens
Never thought I will have to do this, but I think the time is coming and soon I will be breaking my pride and joy and all my money saver/looser...
This is quite rare Sierra Cosowrth 2wd left hand drive.
The car had 2 owners (including me), full service history, genuine 92.000km (57.000 miles) on the clock. About 91.000 the car done on stock power without any modifications. Everything started 2 years ago, when I began to buy parts and to modify the car.
So everything will be for sale soon.
You can see the photos how the car looked when I bought it and how the car looks now in http://public.fotki.com/Stakis/ford-sierra-cosworth/build-up/ .. You will see that this one is very nice well cared example without rost, perfect inside and outside condition. I made with it only about 2500km (2 times on the dyno for live mapping (MSD chip correction) and this was about 800km), so you can understand that it was only built all the time but never driven normaly. All my money was spent on this car.
I live in Lithuania, so most of the light and small parts I will post via signed for Post office service. Bigger and heavy parts will be delivered by courier. So better to state where you live and I will tell how much will cost to deliver.
I am listing parts on ebay. So day after day I will add some of the parts for sale here: http://shop.ebay.co.uk/mj_stakis/m.h...&_trksid=p4340
2. Borg warner T5 gearbox completely rebuilt before 10km. We replaced all synchros (was only 3rd gear one bad) with genuine TREMEC ones, also replaced all the bearrings with quality TIMKEN new ones (all were OK, but I allways try to do everything as good as possible). I placed in it the complete PREMIUM master overhaul kit (all bearrings, gaskets, rings, seals, etc. etc.). The gearbox allways was used on fully sinthetic CASTROL oil as is now also filled with new castrol oil. Price 600gbp.
7. RS500 style Intercooler, XS POWER i believe. Price 140gbp.
8. Aluminium radiator PACE with uprated temp. sensor. Very good condition. Price 200gbp.
11. Adjustable rear beam and rear arms (made like stage 2 adrenaline 6 degree ones which cost more than 1000gbp). The beam was corrected (mounting points moved further), arms have heavy duty big rose jointed rod bearrings, bronze fittings, etc. Price 500gbp.
16. Complete oil cooler setup with remote oil filter mounting (MOCAL take off plate), MOCAL oil cooler, MOCAL thermostat (starts to cool at 80c degrees), Aeroquip hoses, etc. Price 150gbp. ital_cossie
17. Borg warner T5 gearbox short shifter. Price 65gbp.
18. Turbocharger TURBONETICS T3/T4 stage 2 ball bearring (similar to GARRETT GT3071R spec) with polished cold side housing, heatshield on the hot side, externaly gated (but can be used with internal WG). Very powerfull unit! Made 340bhp@1bar and 380bhp@1.4bar on my stock engine. Price 650gbp.
19. 2wd modified exhaust manifold for external WG setup and for EGT sensor. Screamer pipe also available. Price 200gbp.
20. TURBONETICS external WG (good for upto 450bhp). Price 250gbp.
500bhp capable kit (only injectors must to be changed) with ball bearring turbo, external wg and everything matched and prepared to bolt on. And this is only for 1100gbp!!!
23. Group A magnetti marelli coil. Price 35gbp.
24. Genuine magnetti marelli 3bar map sensor. Price 40gbp.
25. Lightweight aluminium FIDANZA flywheel, used for 10km. Price 115gbp.
28. HELIX Autosport 4 paddle clutch with uprated HELIX motorsport cover, used for 1000km. Price 150gbp.
29. OZ RACING Superleggera 17" wheels which glow in the dark, bright orange color. 2 nearly new budget tyres, 2 legal ones, but different. Wheels are like new! Price 420gbp for a set.
30. Autogauge complete 5 gauge kit. smoke series (oil press bar, oil temp c, water temp c, turbo boost 2 bar, exhaust gas temp. c. Price 160gbp for the kit with senders. For extra 20gbp I will include custom made adapters to fit the senders.
32. Panel gauge mounting adapter (inplace of clock with RS logo engraved). Price 25gbp.
35. Electronic boost controler from Japan. T-BAC III. Price 125gbp.
36. GREDDY electornis turbo timer. Price 45gbp.
50. BD14 inlet and exhaust cams. Price 200gbp.
51. Double KENT valve springs. Price 120gbp.
52. 310mm front brakes. brembo calipers. new pads. needs brackets to fit. Price 250gbp.
53. Stock 2wd inlet manifold. Price 25gbp.
54. Used AQUAMIST ERL water injection kit (boost dependant). Complete. Price 200gbp.
55. Used big aluminium water injection tank for water. Price 80gbp.
Old Dec 25, 2009 | 08:49 PM
Mj_stakis's Avatar
Mj_stakis
I can list the parts on ebay, because I am new here in this board... I have good feedback on ebay (Mj_stakis) and allways buy and sell online.
The car is now complete. So I will begin to strip it in January. Also, I will know more exact details about the delivery of heavy and big Items later. But there is no problem at all if you live in the middle of UK (I mean London, Manchester, Leichester, etc.), because every week bus (mb sprinter) is going to UK and i can prepare and send any of the bigger parts or smaller parts for the same price as this will cost to send inside UK. For eg. to send twheels will cost 50gbp, to send engine will cost 50gbp, to send gearbox will cost 50gbp, etc.
I will make a detailed photos of all the parts which you will be interested.
Thank you.
Old Dec 26, 2009 | 10:18 AM
dakunia's Avatar
dakunia
Hi, I'm interested to buy inlet + spacer + thrpttle body, if You decided to break Your car.
And maybe rear beam.
You have PM.
cheers
maciek
Old Dec 26, 2009 | 10:42 AM
Mj_stakis's Avatar
Mj_stakis
No problem m8. Just need the engine or gearbox or turbocharger to have a buyer and I will begin to strip it.
Replied to your PM.
Old Dec 26, 2009 | 11:02 AM
B13 JUS's Avatar
B13 JUS
sorry read you advert wrong.
Old Dec 26, 2009 | 11:21 AM
Mj_stakis's Avatar
Mj_stakis
Soon I will make a lot of quality photos for you to see the parts I will be selling.
Thank you.
Old Dec 26, 2009 | 12:12 PM
Rozvor's Avatar
Rozvor
Hi. Interest on
12. Aluminium polished Spec-r water swirl pot. Price 50gbp. Can come with silicone blue samco hoses + 15gbp.
13. Bailey oil/air seperator, aluminium polished with hoses (includes block adapter). Price 70gbp.
14. Aluminium polished header tank with glass. Price 65gbp.
24. 3bar map sensor. Price 40gbp.
54. Used AQUAMIST ERL water injection kit (boost dependant). Complete. Price 130gbp.
55. Used big aluminium water injection tank for water. Price 60gbp.
Please send me pics and total amount with shiping costs to Spain
Old Dec 26, 2009 | 12:43 PM
timotei1980's Avatar
timotei1980
Hi, i'm interested in the Adjustable rear beam and rear arms. Who carried out the mods to it and how much for postage to portsmouth, England.
Thanks.
Old Dec 26, 2009 | 02:10 PM
Mj_stakis's Avatar
Mj_stakis
All PM's replied.
Old Dec 26, 2009 | 05:42 PM
jose999's Avatar
jose999
Hello.
i am interested to buy this car with all parts. i need lhd cosworth. what you think?
Old Dec 26, 2009 | 05:59 PM
Mj_stakis's Avatar
Mj_stakis
I replied to your PM. Thank you.
Old Dec 26, 2009 | 10:12 PM
rs_cos's Avatar
rs_cos
3 door resto in progress
hi mate interested in 11. price on postage please
Old Dec 26, 2009 | 10:30 PM
turblower's Avatar
turblower
im definately intrested in the oil cooler....
Old Dec 27, 2009 | 06:40 AM
Mj_stakis's Avatar
Mj_stakis
PM's sent. Thank you.
Old Dec 29, 2009 | 10:56 AM
manoj's Avatar
manoj
Hi,
sent you a PM re: LHD Cosworth ABS Brake Servo/Fluid Reservoir/ABS blocks.
thanks,
Manoj
Old Dec 29, 2009 | 01:09 PM
mechanic28's Avatar
mechanic28
not being funny but it seems abit strange that everyone who is interested in buying bits from you is a low poster and from outside the uk!
might be me looking into it completely wrong tho!
Old Dec 29, 2009 | 03:22 PM
Mj_stakis's Avatar
Mj_stakis
not funny at all. If some of you want I will list the wanyed parts on ebay, so you can securely buy and have protection.
as I said, next week I believe I will know if I am breaking the car or not. There is an idea to get back to stock. So everyone who wants aftermarket parts, all of them will get.
Here I have listed some of my honda parts for sale, item number: 220531984110
Old Dec 29, 2009 | 08:38 PM
Leslie DG's Avatar
Leslie DG
still d r ift
what about the complete car?
we looking for a good base for a racecar, that means we interested the shell, suspension, brakes, engine (without wiring and ecu), gearbox etc.
pm me please with details on this.
Old Dec 30, 2009 | 04:50 PM
boost mad's Avatar
boost mad
What make are the cams ? would you be willing to split ?
Old Jan 3, 2010 | 11:16 AM
timotei1980
Hi, Have you started breaking this yet or are you still undecided?
Cheers.
Old Jan 3, 2010 | 11:59 AM
Mj_stakis's Avatar
Mj_stakis
2 potencial buyers of complete car must say answer today or latest tommorow. So tommorow I will tell exactly and will start stripping the car if they don't buy. Also, one person wants this car to be returned to stock, so he also will tell me today if he buy it or not. that's why I am still waiting as I am really very sad to start to break and would be much happier to sell it complete or returned to stock.
Thank you patience.
Old Jan 3, 2010 | 12:03 PM
Mj_stakis's Avatar
Mj_stakis
I believe they are made by KENT cams? so are the double valve springs. these i bought from a kit car cosworth which was running 500bhp, so i don't have more detailed information about them.
Old Jan 5, 2010 | 11:21 AM
Mj_stakis's Avatar
Mj_stakis
I am splitting the car and selling it in parts. Tommorow I will make a movie of the engine running, so that potential buyers can see how it is running, also photos of various parts. More photos will be then the parts will be out the car.
So i will contact everyone soon, who putted their names near the parts. Also I will try that every part will have photo for you to have an idea of condition, etc.
Old Jan 6, 2010 | 05:59 AM
Mj_stakis's Avatar
Mj_stakis
Old Jan 6, 2010 | 11:50 AM
timotei1980
PM SENT regarding rear beam
Old Jan 8, 2010 | 06:48 PM
Mj_stakis's Avatar
Mj_stakis
Today i started to stirp my car. the suspenion is out of the car. as are all the parts arround engine. during the weeking i will try to remove the engine. so soon i will post a lot of new photos with the parts.
http://public.fotki.com/stakis/breaking-lhd-sierra/parts-4sale/
Old Jan 20, 2010 | 07:33 PM
21turbojon's Avatar
21turbojon
PM send. I´m interesting in rear beam.
Thanks
Old Jan 25, 2010 | 09:59 AM
Jasesapphy's Avatar
Jasesapphy
do you have throttle body and 044 pump
Old Jan 25, 2010 | 12:39 PM
Mj_stakis's Avatar
Mj_stakis
EECIV throttle sold. I have 2wd stock throttle body for sale. complete with TPS sensor, etc. 13gbp + 7gbp postage.
I have stock 2wd fuel pump only.
Old Jan 28, 2010 | 10:46 AM
Mj_stakis's Avatar
Mj_stakis
Keep away from member Rozvor. Agreed for total amount with postage, etc. and no reply from him. Was online, but haven't responded to my messages. So the parts which Rozvor marked are for sale again.
Old Feb 1, 2010 | 06:50 PM
dakunia's Avatar
dakunia
I received my parcel today. Smooth international transaction, great communication with Marius (Mj stakis) and reasonable postage price. ST Inlet + throotle body and spacer as described, and wrapped up according to best british standards
many thanks.
maciek
Old Feb 1, 2010 | 08:19 PM
Mj_stakis's Avatar
Mj_stakis
many thanks.
maciek
Thanks suzuki123. Good luck to you using the stuff on your cossy.
Old Feb 3, 2010 | 05:18 PM
cosysop's Avatar
cosysop
Marius, PM send.
Old Feb 4, 2010 | 05:59 AM
Mj_stakis's Avatar
Mj_stakis
All PM's replied. First post updated, sold parts removed.
Old Feb 4, 2010 | 09:40 PM
AndyPen's Avatar
AndyPen
pm'd on interior questions
Old Feb 5, 2010 | 05:36 AM
Mj_stakis's Avatar
Mj_stakis
Interior is sold.
Thanks
Old Feb 13, 2010 | 11:20 PM
cosysop's Avatar
cosysop
PM'd
Old Oct 27, 2011 | 02:44 PM
Stakis's Avatar
Stakis
still have a lot of parts for sale.
bd14 cams, intercooler, gearbox, fidanza flywheel, etc.etc.
Old Oct 27, 2011 | 05:46 PM
Sta1n1's Avatar
Sta1n1
clutch and pressure plate ?
Old Oct 27, 2011 | 07:50 PM
RSLUBBY's Avatar
RSLUBBY
Love those wheels have you still got these
Ian
