the cost of tuning a frs?
hi there ive owned my focus rs now for 6 months but im looking into modifing it. im just wondering how much it would cost to get up to the 330bhp mark and wheres the best places to buy and go to???
its got a mongoose and decat exhaust system already and a bluefin, what would i need to reach the 330bhp mark?
cheers.
cheers.
cheers.
cheers.
if your handy with the spanners and you can fit it all yourself then it wont cost more then :-
forge actuator run direct (90), manifold (600) hybrid turbo ( see johnfrs over on the rsoc
a word of advise though, do you know which base map you have on the ecu?? (either AE or AF)
AE is the earlier one and is the one you want, as AF has a misfire around 5k rpm and only gets worse the more you mod the car..
if you go on the rsoc again and find lami or carl, they can find out which base map you have and can supply you with the AE base map, plus add TUNA ontop of it (which is an uprated remap better then BLUEFIN)
cheers mate, thanks for the info
thats not 2 badely priced and the map is af the later map
so how much would the ae map and tune cost to get done and where abouts are they based?
cool, so with all the mods would it be best to run a boost controller and uprate the charge cooler or change it to a intercooler and what sort of clutch would be best for that sort of power cause i dont want do all that and clutch starts to slip lol
the standard cooling system is ok for that power, there is a little mod that doesnt cost a penny that you can do to help that brings intake temps down a few degrees
its up to personal preference if you want to uprate the pre rad or go air to air, every little helps but it isnt needed, theres a couple of lads running near 400 with the standard setup so its cool enough, but id say thats probably its limit.
ap racing organic clutch will be ok with that lot, thats the one up from the standard clutch they come with.
the standard clutch has been known to take 300bhp+ so i wouldnt bother changing it until you find the limit of yours
just make sure you get the boost setting on your actuator checked and setup, get it rolling roaded just do double check your fueling and make sure the chargecooler pump is running.
SMILER258
Sep 28, 2015 09:04 AM
