how low can you go before problems
Old Dec 20, 2009 | 09:42 AM
marky_g's Avatar
marky_g
Fleet Manager
Default how low can you go before problems
ive had mk4 escorts before my focus and 60mm drop is not grate for an every day car doin alot of miles taking into account angel of drive shafts and all that,30 or 40 was awlays the max for a daily car.
is this the same on the focus????
Old Dec 20, 2009 | 11:01 AM
MisiekT_PL's Avatar
MisiekT_PL
yes, -40mm is a max for daily drives, unless you want to worry about every bump and pothole
Old Dec 20, 2009 | 04:53 PM
airzfocus's Avatar
airzfocus
mines drop 50mm erm i dont find the drive bad just that the driveshaft bearing wears quickly and makes a slight droaning noise, doesnt really bother me to much, looks better dropped!
Old Dec 20, 2009 | 05:10 PM
jammerrs's Avatar
jammerrs
id say about 40mm, most cars are about 40mm befroe you sart to get a bit too low for everyday driving
just do what the chavs do round here and take the springs off bloody idiots
Old Dec 20, 2009 | 11:02 PM
marky_g's Avatar
marky_g
Fleet Manager
thanks peeps 30/40mm it is then
Old Dec 22, 2009 | 05:57 AM
Turbo Al's Avatar
Turbo Al
get it decked!! my wifes focus is down 40mm on 17s, even she says it needs to be lower as there is still a fair gap in the arches......and she uses it every day for the school run and is most certainly not a boy racer.
anyone got 60mm srings for sale?
oh, good luck removing your standard height rear springs
Old Dec 22, 2009 | 12:18 PM
MisiekT_PL's Avatar
MisiekT_PL
why?! easier than changing a headlight bulb
Old Dec 22, 2009 | 09:01 PM
marky_g's Avatar
marky_g
Fleet Manager
surely just undo where the wishbone joins to the chasis job done?
im thinking about damage to cv joints not how low i can actually go ive seem them lowred over 100mm not grate for drive shafts but looks good
40mm sounds good to me
Old Dec 23, 2009 | 05:36 AM
Turbo Al's Avatar
Turbo Al
youve obviously never came across seized bolts in the rear sus arm bushes then?!
Old Dec 23, 2009 | 11:28 AM
supertouring230's Avatar
supertouring230
Smile
to get round this i cut the standard springs in half on mine and slotted the new ones in cause they were 60mm pi springs.
lowered the front end loads but not the back end,i had escort cosworth alloys on mine with 205/40/16 tyres but every pothole,bump etc u will feel going so low also we have speed humps round my way and honest to god after a week i wish i had never lowered it as it ruined the car.might look good but thats about it.as it drove like shit and every bump in road sounded like i hit a brick wall.the focus is the worst car i have every had for lowering as even the sills scrape on the speed humps
your choice but not recomended
Old Dec 23, 2009 | 12:43 PM
marky_g's Avatar
marky_g
Fleet Manager
speed humps and poy holes are not my concern its the driveshaft angel
Old Dec 23, 2009 | 03:28 PM
MisiekT_PL's Avatar
MisiekT_PL
as far as changing rear springs - if you compress them on the car you can take them out quite easily, I'm not a mechanic but I've seen the process on a couple of focis...
Old Dec 24, 2009 | 06:01 AM
Turbo Al's Avatar
Turbo Al
not being smart or wanting to get into a debate but i cant see how you would or could get spring compressors into the rear springs. all the garages ive worked in all have the same type of compressors.
im sure marky will tell us how he gets on when he does it
Old Dec 24, 2009 | 06:36 AM
marky_g's Avatar
marky_g
Fleet Manager
same was as a mk4 escort as far as i can see i'll just undo where the wishbone that holds the spring bolts to the chasis. if the bolts are sized ive got a nut splitter i'll just get some new bolts, got ait tools anmyway so cant see it bein a problem.
as turbo al says ur not likly to get compressors in there i dont think, ive certinly never used them on rears before
Old Dec 24, 2009 | 06:41 PM
airzfocus's Avatar
airzfocus
i did mine and come across the seized bolts in the bushes, wot a nightmare! car was off the rad for week n half after that, my mate did his springs on his and just jacked it up and prised them out with crow bar, i thought it was a lil bit dangerous in my opinion, but he said it was peice off piss, wish i had done mine like that!
Rammer46
Sep 18, 2015 08:31 AM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
landaqmabba
Sep 15, 2015 07:16 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Tank Mike
Sep 10, 2015 07:56 AM
