GUTTED!!! 3dr Breaking, everything going.
Old Dec 17, 2009 | 08:22 PM
TiB's Avatar
TiB
Default GUTTED!!! 3dr Breaking, everything going.
Well due to the economic climate taking its toll and needing somewhere to live having to come first i have to break the car
A few people have suggested just selling some parts and then rebuilding it when things pick up but i just cant do that, if its coming apart i need the whole lot gone for a fresh start because i hate having it there and not using it... its just too damned depresing. So i'm going to pay some bills off and buy something cheaper to do me a year or until i can get on top of things again and then build something else (or maybe go hunting for my bits back ha ha)
Before anyone asks... yes i'll sell the thing complete if someone want it but it goes for nearly the value of the parts (prob a quite a bit less cos they is bound to be extra parts i've forgotten) because i'm only selling up for financial reasons so the whole car minus the gas kit is £14950 no offers sorry, but may px mk1 focus rs or low priced focus st, or even at a push something different that is interesting but must be cash my way as thats the whole point of doing this
I am advertising it now but will be starting dissasembling it mid jan,
I have put prov sold next to a couple of items as a couple of mates have asked for first dibs but if its something you want please post as you will get next refusal in order of contacting me.
1, Wheels, Comp mo's 8x17 in white, come with ok ish 215/40/17 £575 prov sold
2, Tyres, Toyo R888's very low milage 2x 205/40 & 2x 235/40 £275 prov sold gav diamond
items 3 to 13 can be bought together as a matching set slightly reduced (£6250)... the engine made 649 bhp and 551 ftlb at 30psi so you know the parts work together
3, Head, 27mm inlet 25mm ex, custom cams (large Ahmed cams), uprated valve springs, valves recently reseated £2000
4, Gt3582r approx 1000miles inc braided water/oil pipes £775
5, Tial 44mm external wastegate inc screamer pipe £ 250
6, Tubular exhaust manifold couldnt tell you the make but it came from sweden, £675 prov sold c20trb
7, EEC4 inlet and throttle body, modified for greater air flow and tapped for air temp sensor, also spacer welded into place on the cover side £250 prov sold james kiely
8, Seimens 83lb injectors £150
9, Bailey turbo Damper £50 prov sold Rscossiegaz
10, Tube Torque exhaust.. 4inch downpipe into 3 1/2inch into 3 inch main section, Modified to sit correctly with turbo sat on tubular manifold so ideally go together £625
11, P8 ECU £325
12, Turbo/exhaust adapter (converts to 3 stud fitting, from reyland) £50
13, Bottom end inc 200block, long studed inc studs, .5mm low comp pistons approx 7.1/1, will have a polish on the crank and new mains/big ends before it goes, high pressure oil pump only done 4k miles approx, £1350
14, Single air injector £150 prov sold jdcrst
15, Braided complete engine loom for coilpack conversion inc leads and coilpack £475 prov sold
16, Mirror image breather tank and all braided hoses adapters etc £235 prov sold
17, Pro alloy 65mm intercooler (the one with the ducts on the front) £300
18, Pro alloy rad and slim fans £325
19, Spec R header tank with sight glass £95
20, Oil cooler, mogul and braided lines £120 prov sold
21, Swirl pot £50
22, Alloy 3dr washer bottle £50
23, Alloy power steering bottle £35
24, Tarrox 6 pots, bells and brackets (front) £675
25, 4x4 rear calipers, sliders and bosch vented discs all less than 200 mile old £180
26, Complete rear diff/beam/shafts, beam is modded to accept larger rear diff from a maseratti bi turbo thing.. it has 108mm output flanges (std 2wd size so 2x short side shafts fit straight on and also has an adapter so the std prop fits straight on too ) it is a hydro lock style diff but quaife do make an ATB unit that fits in, i have NEVER managed to break this diff in anyway in over 12months so its proven itself, £875
27, 3dr hubs £100 each
28, Pair 3dr adjustable track control arms £100
29, Pair compression struts £100
30, Cosworth T5 gearbox, was full brand new internals approx 12months ago £450
31, RS500 front bumper inc grills £850 prov sold paulnyrs
32, RS500 upper whale tail, 2 caps missing £750 prov sold paulnyrs
33, RS500 lower spoiler (has the 'c' on the part number) £275 prov sold paulnyrs
i'll sell 31,32 and 33 for £1500 if bought together. (if anyone thinks i've priced these wrongly high or low please say)
34, 3dr shell with ID in white with martini graphics.. including bonnet, doors, mirrors, tailgate and all glass, the car was reshelled approx 10yrs ago with a new shell, this car was originally built by severn valley and was one of their magnificent 7, they did the complete reshell work, it is solid underneath with no welding at all had or needed, it has the adrenaline chassis connector bars fitted wich made a huge difference.. now.. someone in the know may be able to shed some light on this but it has a 909 number on the colour tag on the slam panel, the outside of the car really requires 2 wings as they are starting to blister and one is dented where it was kicked.. (i never had it repaired because i always wanted to fit a thunder saloon kit to it but never quite had the bottle or the money for wheels to fill the arches) i will leave the kit on it but the arches are rippley but the skirts are ok, when the arches are removed it will need a bit of attention to the metal lips because when they were cut back fpr wheel clearance it appears they weren't sealed properly apart from that it really good condition. £2950 (again... if someone thinks i'm well out on price up or down please advise otherwise)
35, Corbeau front bucket seat fitted to sierra runners.. dont know what model but its only £50
36, Full trim, front and back seats, door cards (drivers elbow rest sagged) rear cards, dash upper and lower some cracks sorry, parcel shelf with speakers. £500
37, 1/2 roll cage... was an fia approved thing wich has been shortened to fit the car with carpet and roof lining in place, powder coated in silver £95 prov sold Rob Carden
38, Front strut brace with a bracket for coilpack £100 prov sold
39, Collins monitor pro £300 prov sold
40, Rs 4 spoke on snap off boss £120 prov sold
41, 3 Racetec gauges in a vent plate holder, boost 2.5bar, fuel pres, oil pres and all relevent hoses/pipes etc £100
42, Dynojet wideband AFR with datalogging box, 52mm analog gauge.. pretty much the same as this but with white face.. £250 prov sold
43, Pair of front AVO coilovers, unknown spring poundage £100
44, Pair rear koni's £30
45, starter motor £30
46, alternater £30
Obviously everything is plus postage and i will add more as i think about it,
If there is something you need and i havent mentioned it above please ask.
Its a first come first served basis and i dont get on all the time so if you really want something i suggest you text me on 07973744159 to secure an item, i know its a bad time of year for this but it will be 2-3 weeks before it gets pulled apart and a deposit will secure the parts required till its broke.
Well thats it for now, i'm going off to cry somewhere ha ha
Old Dec 17, 2009 | 08:32 PM
pacwest's Avatar
pacwest
Puller of the Wrench
Epic "for sale" thread.
Good luck!
Old Dec 17, 2009 | 08:40 PM
tezmanian devil's Avatar
tezmanian devil
would you sell the splitter from the front bumper seperate atall?
if so, how much for this posted please?
Old Dec 17, 2009 | 08:45 PM
TiB's Avatar
TiB
The splitter isnt on the bumper... one side of it was broken so going to see if i can get it repaired before doing anything with it.
Old Dec 17, 2009 | 08:46 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
gutted to see it broken fella,
still good luck on the financial situation ,
beef
Old Dec 17, 2009 | 08:53 PM
Mr RS500's Avatar
Mr RS500
Lee
Ill take 31 32 and 33 for £1500 please mate as long as there in good nick and havent had repairs
cheers Paul
Old Dec 17, 2009 | 08:58 PM
jacko's Avatar
jacko
legendary 3door shame to see it go good luck lee
Old Dec 17, 2009 | 09:02 PM
KSA-Cossie's Avatar
KSA-Cossie
Gutted for you m8.
Old Dec 17, 2009 | 09:10 PM
tezmanian devil
is it a proper rubber one, or a fibre glass copy?
Old Dec 17, 2009 | 09:18 PM
andy130's Avatar
andy130
fuck me sad times,
i hope some one buys it in one lot,
Old Dec 17, 2009 | 09:34 PM
TiB's Avatar
TiB
Its a propper one mate. just not really sellable at the mo i think?? unless there is a scrap value for them lol
WENNY's Avatar
WENNY
shame to see another legend of a car being brokebut there woth more in bits, some nice bits there at sensible money
Old Dec 17, 2009 | 09:47 PM
RobCarden's Avatar
RobCarden
358bhp
hi mate if this is still available i'll have it!
cheers!
rob
Old Dec 17, 2009 | 09:51 PM
RSCossieGaz's Avatar
RSCossieGaz
put me down for the bailey turbo damper pls!
Old Dec 17, 2009 | 10:01 PM
tezmanian devil
i dont mind abit of damage, i'll be cutting it to fit it to a mk5 rs2000 front bumper anyway
i'v got a fibre glass one, but that will be far to much hassle trying to fit, so need a rubber one idealy...
Old Dec 17, 2009 | 10:03 PM
RSLUBBY's Avatar
RSLUBBY
got any pics of the cage and seat
Ian
Old Dec 17, 2009 | 10:05 PM
Its Dave's Avatar
Its Dave
Sorry to see this lee, looks like we are all doing it
Good luck with selling the parts
Dave
Old Dec 17, 2009 | 10:21 PM
TiB's Avatar
TiB
one half is ok.. the other is in 2 pieces, its a clean break though, make a ball park offer and if its good enough i'll take a pic and see what you think.
Old Dec 17, 2009 | 10:24 PM
tezmanian devil
ok, errrrrmm, i dont know what these are worth really, and please dont be offended if my offer is stupid...
£100 + post could also give you my fibre glass one aswel if you want one for the bumper?
Old Dec 17, 2009 | 10:28 PM
TiB's Avatar
TiB
If i could of been offended i wouldnt ask you to offer ha ha, i'll think on tonight mate, you'll get first refusal though if i decide to sell
Old Dec 17, 2009 | 10:33 PM
tezmanian devil
okie dokie, cheers dude
Old Dec 18, 2009 | 12:03 AM
mechanic28's Avatar
mechanic28
there are no parts listed?what are peeps going on about 33,34 etc???
Old Dec 18, 2009 | 12:16 AM
Tom_Cortina's Avatar
Tom_Cortina
+ 1
Old Dec 18, 2009 | 12:29 AM
TiB's Avatar
TiB
all fixed
Old Dec 18, 2009 | 12:36 AM
TiB's Avatar
TiB
Dave
Cheers.. so much i still wanted to do with it but needs must i'm afraid
Old Dec 18, 2009 | 05:46 AM
cressy's Avatar
cressy
sorry to see this post mate know how you feel i had to do the same to my s1 early this year thanks to the x-wife.hope it all works out for you in the near future
Old Dec 18, 2009 | 06:10 AM
Rozvor's Avatar
Rozvor
PM for 19, 21, 22, 23, 24 and 29
Old Dec 18, 2009 | 07:30 AM
Shell's Avatar
Shell
Dave
Daddy Thrash will be quiet next year... Just gunna end up being a bunch of stage 3 Saphs at this rate! ha ha x
Old Dec 18, 2009 | 07:40 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Real shame to see it broken lee, but needs must! Are those power figures on or off gas?!!!
Old Dec 18, 2009 | 07:54 AM
jdcrst's Avatar
jdcrst
I'll have the air injector pal. Does it have the little loom with it to change from a twin injector?
Jon
Old Dec 18, 2009 | 08:11 AM
Stu @ M Developments's Avatar
PassionFords Creator
Sad Times lee.
Old Dec 18, 2009 | 08:19 AM
TiB's Avatar
TiB
They were off gas. just seemed to get everything come together and not had the chance to set some times oh well, nowt i can do now.
Old Dec 18, 2009 | 08:21 AM
TiB's Avatar
TiB
Jon
Dont know about the twin inj's... it plugs into the existing amal valve plug on the loom.
Old Dec 18, 2009 | 11:22 AM
mechanic28's Avatar
mechanic28
number 7 is that a st inlet?
Old Dec 18, 2009 | 11:36 AM
TiB's Avatar
TiB
yes mate but a deposit is on its way.
Old Dec 18, 2009 | 12:00 PM
mechanic28's Avatar
mechanic28
ah ok lee off here is after one was going to point him to it lol
Old Dec 18, 2009 | 12:24 PM
jdcrst's Avatar
jdcrst
That'll do me pal I'll have the air injector. Pm me some payment details please.
Old Dec 18, 2009 | 05:44 PM
c20tbo's Avatar
c20tbo
Money deposited Lee as described, Thanks.
Old Dec 18, 2009 | 06:00 PM
Sticky.'s Avatar
Sticky.
Lee, have you got any braided fuel lines?
Old Dec 18, 2009 | 06:09 PM
TiB's Avatar
TiB
no sorry,
