vibration from my cossie
got a problem with my cossie when driving im getting a vibration that comes and goes but especially bad when turning left.I feeling its possible balljoint or cv joint that fooked.
Its doing my head in making the car horrid to drive any idears wot my be the cause of this ?
I hve similar problem - sometimes (very rarly) there is heavy vibration when going through very fast left hand corners but only if I'm not going very close to the limit. Very specific condition. No idea why it happens, And I can't find it out for some months now.
I've got the same problem with my Saph 4x4 in right hand corners. Only while or just before sliding the front wheels with the steering wheel turned more then 90°.
This only started happening after i 'renewed' my left-front driveshaft because both boots were leaky. It always drove fine & without noises or vibrations.
The one i put in came out of an Xr4x4, and was fine whilst in the Xr4x4. Only difference is that it is 15 millimeters longer than the Cossie one. But it seems to have enough tolerance, the inner spring is not fully compressed when the driveshaft is straight (car on ground).
Wheelbearings seem o.k. & exhaust is not touching the propshaft(s).
Any suggestions what might cause this vibration/noise??
Russ Payne
Sep 25, 2015 08:29 PM
