Cosworth Brembo 6/8 pot Brake Brackets !
Old Dec 17, 2009 | 11:57 AM
Touring Car Spares's Avatar
Touring Car Spares
Default Cosworth Brembo 6/8 pot Brake Brackets !
Pair of Alloy Brake Calliper mounting brackets with a radial mounting point PCD of 180mm and std cosworth hub fixing PCD of 90mm .
These can be used with Brembo competition calipers ,definitely 6 pots and possibly even the 8 pots ive seen being advertised here recently ( make your own checks tho ! ) .If i recall the Discs were 356mm x 32mm , but you can machine a bit off or add spacers to vary whichever size you choose upto 380mm . £150 the pair , £5 carriage ,paypal add 4% please !
Old Dec 27, 2009 | 05:17 PM
nuttynil's Avatar
nuttynil
RS nutta
You have pm .
Old Dec 29, 2009 | 12:36 PM
nuttynil's Avatar
nuttynil
RS nutta
Measured the radial mounting holes for the ap 7040 it measured 150mm so unless these can be redrilled I'm going to have to source some diff ones.
jason_nike
Aug 18, 2019 10:53 AM
Wilsfoci
15
Mar 30, 2016 10:26 PM
james kiely
Aug 28, 2015 08:58 PM
Aug 14, 2015 07:29 AM
RsS2daz
Aug 14, 2015 05:26 AM
