Which ecu's ?
Old Dec 10, 2009 | 09:42 PM
Mk1-stu's Avatar
Mk1-stu
Patronus
Default Which ecu's ?
Will work with the 130 spec 1.8 zetec - gotta be non pats
The only one i remember is DEEP and i can't find any. Can i use a 2.0 mondeo one ?
cheers in advance.
Stu.
Old Dec 10, 2009 | 11:52 PM
xr4x4rs's Avatar
xr4x4rs
all mondeos have pats mate
you need an early xr3i
Old Dec 11, 2009 | 08:22 PM
Mk1-stu's Avatar
Mk1-stu
Patronus
ok. any one know the ecu code ?
Old Dec 11, 2009 | 08:40 PM
3i_gaz's Avatar
3i_gaz
all mondeos dont have PATS, if using a mondeo ECU it has to be a very early one DEEP is the correct one, thats what i had in my 2.0 fiesta si.
if my memory's right you may have to swop some pins round on the ecu plug when switching to a 2.0 ecu too. bot not certain whether thats on every escort/fiesta loom.
Old Dec 11, 2009 | 09:18 PM
Pob's Avatar
Pob
DESK ,DEEP ,DEWY
Full list of ecu's and codes
http://www.carclinicmagazine.com/ford_ecu_list.html
Old Dec 11, 2009 | 09:34 PM
rs220bhp's Avatar
rs220bhp
You can use either a deep/desk/dewy ecu from a mondeo with a fiesta Si loom but remember these are designed for a 2l, the best ecu for a 1.8 is the cult from a rs1800, this can be used on the Si loom, these are external pats and internal edis.
Other option is an early rs1800 or 130 spec xr3i which use ecu code 2fbc, this has no pats and external edis so you would need the correct loom for this ecu and also the edis4 box which plugs into the loom.
Old Dec 11, 2009 | 10:38 PM
Mk1-stu's Avatar
Mk1-stu
Patronus
i've got all the wiring from the 130 spec the engine came from, it just didn't have an ecu with it.
Cheers for the input and that link !!
appreciated
Old Dec 12, 2009 | 12:10 PM
rs220bhp's Avatar
rs220bhp
What car did it come out of and what year? So you know if its internal or external edis loom?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
