Focus RS mk1 bits..
Dec 9, 2009 | 06:25 PM
Focus RS mk1 bits..
I have a few bits and peices left over from my conversion. All parts have covered 15,000 miles, the car ended life in a ditch apparently.
Full interior loom
A lot of plugs and bits from the engine loom
Outer cv joints
Turbo support bracket
Both Lambda sensors
standard flexi section
air intake hose with standard D.V
Standard boost hoses
Power steering reservoir
power steering mounting bracket
Charge cooler reservoir
Standard acutator
standard oil feed
Open to offers PM me..
Cheers Dan
Dec 13, 2009 | 06:57 PM
Dec 13, 2009 | 07:02 PM
Dec 13, 2009 | 07:47 PM
Jan 5, 2010 | 07:09 PM
All avaliable still apart from the turbo support bracket, which is provissionally sold.
Jan 6, 2010 | 06:41 PM
Pic of standard oil feed please squire.
Jan 6, 2010 | 08:35 PM
Will sort one out tomorrow.
Jan 7, 2010 | 07:07 PM
Any luck mate?
And a price aswell if you can, posted to Lincoln.
Jan 7, 2010 | 07:51 PM
Quote:
Originally Posted by
focusrrx87
gearbox???
sum1's got a gearbox 4 sale further down the list! 500 bad bois
Jan 10, 2010 | 07:13 PM
oil feed sold
Loom prov. sold.
Jan 10, 2010 | 07:17 PM
Have you got the rear calipers Dan?
Jan 10, 2010 | 07:31 PM
No sorry. there were some going for around Ł80 on rsoc.
Jan 11, 2010 | 02:36 PM
Could you pm me a price for both subframes with arms and hubs please. Russell.
Jan 11, 2010 | 05:56 PM
russ_si
Sorry, i have only got what is on the list.
Jan 12, 2010 | 12:42 AM
Can you get the steering wheel and/or pedals?
Jan 12, 2010 | 04:37 PM
Jan 12, 2010 | 05:55 PM
Few pictures..
Intake pipe with standard DV and boost solenoid.
Ecu with transponder, (no key chip) Been told a chip can be programmed to it.) It is believed to be superchipped also.
Boost hoses.
Thermostat Housing No stat inside
Central locking module
Jan 13, 2010 | 08:35 PM
Jan 17, 2010 | 12:42 AM
how much for the post cat lambda mate? (the one on the flexi pipe)
pm me
Jan 17, 2010 | 12:43 AM
oh and the intake hose with the solenoid e.t.c.
Jan 19, 2010 | 06:47 PM
Do you have the wiring from fuse box to the cooling fans by any chance???
Jan 20, 2010 | 02:41 PM
i expect so.. Dont want to be cutting it off of the loom though.
Jan 20, 2010 | 04:19 PM
it should be its own loom(not part of eng. loom)
Jan 23, 2010 | 12:56 PM
dns2491
Full interior loom
Outer cv joints
Both Lambda sensors
Standard acutator
standard oil feed
Cheers Dan
set of complete rear hubs?
Jan 23, 2010 | 02:35 PM
Jan 24, 2010 | 03:21 PM
dns2491
No sorry.
no probs just bought new rear hubs from henry himself. cheers
Jan 28, 2010 | 06:02 PM
Jan 29, 2010 | 05:50 PM
Do you have the front breather pot?
Brian
Jan 29, 2010 | 07:38 PM
Brian
Brian
Not sure what you mean sorry?
will have a look then
Feb 1, 2010 | 12:33 AM
how much for flexi section of exhaust ?
john
Feb 15, 2010 | 07:57 PM
how much do u want for standard actuator and is it still strong as my 1 is weak. just bought dreamscience and apparently it wont boost properly because my actuator.
Feb 15, 2010 | 08:39 PM
pm me with an offer. it has only done 15k so should be fine.
Feb 24, 2010 | 11:40 AM
help
once again rs in garage this time power steering problem need the high pressure power steering pipe which runs along the front of the car the short peice if possible
its 555mil long
and
9 mil in diameter
thats if you have it of course
Feb 24, 2010 | 04:58 PM
Mar 1, 2010 | 10:55 AM
the price for the blue lambda sensor?
thanks
Mar 3, 2010 | 08:40 PM
Mar 5, 2010 | 06:25 PM
do you have a ecu for rs focus for sale?
Mar 7, 2010 | 08:34 PM
stu22041987
yes no key chip though.
Mar 21, 2010 | 10:51 AM
I sent you the money 5 days ago for the dump valve and boost solenoid. check your private messages.
Mar 26, 2010 | 09:26 PM
water pump by any chance man
