M-Tech V4 ECU - first impressions
Well firstly a big thank you to Matthew for getting the V4 over to me
and all i can say is i'm impressed;
a. its tiny!!
b. build quality looks good (especialy the amp connector and its usb compatiable)
c. i understood the manual & the software
can't wait to get it in the fiesta and get it running (run into a snag with the gentleman charged with doing the wiring integrating with the standard stuff is a bit over his head) so if your reading this do you fancy doing it Matthew?
pictures of what i got in the box, note the lables on the pigtail loom are mine and are just pin numbers there is also a cd but im sure you all know what they look like, i have pinched some internal shots from the M-tech website as i didn't want to open mine
cheers - James -
a. its tiny!!
cheers - James -
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
Sep 14, 2015 09:04 PM
