cossie gr A or WRC air sensor location
Old Dec 8, 2009 | 08:03 PM
sygjim's Avatar
sygjim
Default cossie gr A or WRC air sensor location
why on the wrc or gr A cossie; the temp sensor is olcated on the tb and not on the plenum ???
Old Dec 8, 2009 | 08:35 PM
sygjim's Avatar
sygjim
nobody ?
Old Dec 8, 2009 | 08:40 PM
creator's Avatar
creator
is it something to do with running anti-lag?
Old Dec 8, 2009 | 08:42 PM
mechanic28's Avatar
mechanic28
something to do with water injection maybe?
Old Dec 8, 2009 | 08:44 PM
sygjim's Avatar
sygjim
perhaps the real air temp is here, not on the plnum which has some heat from the head ... but not sure
Old Dec 8, 2009 | 08:48 PM
mechanic28's Avatar
mechanic28
the air would be bloody cold rushing through there fella,why on most cars you get coolant running through it,to try and keep the throttle body from freezing up
Old Dec 8, 2009 | 08:55 PM
Steven_RW's Avatar
Steven_RW
Im not so sure it would be cold? It is after the turbo (very hot on some setups), cooled by an intercooler (not always such a good one in most setups) and then 1 ft of pipe later it is in that throttle body, so the output of the intercooler is the temp the throttle body will see. Under load that will be hotter than "bloody cold".
If that small a surface area at a reasonably close to ambient temperature could really cool air in that short a period of time, we wouldn't need intercoolers.
I can't see why anti lag would want to see the temperature 1 nano second before it normally would, with the air temp in the plenum. Maybe the plenum is cast differently and they don't want to drill it? Even then that is a very random guess, as I don't know either, without seeing so much more of the engine and setup.
RW
Old Dec 8, 2009 | 08:58 PM
mechanic28's Avatar
mechanic28
RW
Very true on a turbo set up!but think you woud be surprised how cold the air gets going through the tb!it wont be ambient temp thats for sure!
Old Dec 8, 2009 | 08:59 PM
J1mbo's Avatar
J1mbo
B1mbo
the throttle body should be in the region of 25-45 degrees really as if carge temps exceed that then your intercooler isnt really up to the job i wouldnt think they can ice up,
im not 100% sure here, but on the wrc escos plenum they run a anti lag valve in the side of the plenum just where the temp sensor normally is so maybe something to do with that, could be way off,
i will ask the old chap tomorrow he has one of the grp a throttle bodies at work im sure he'll know why
jim
creator's Avatar
creator
hhmm i duno mate just that if you look at a normaly cossie throttle bodie (doesnt run anti-lag) that doesnt have one so i came to the conclusion that a grp a one will be runing anti-lag so it had something to do with the anti lag set up.i take it im wrong then
Old Dec 8, 2009 | 09:06 PM
markk's Avatar
markk
its heat soak from the cylinders, when the engine is running the valves open and close, when the throttle is shut i.e stage starts the heat sits in the plenum, thus t
excess heat to the sensor, thus massive ignition retard on stage starts i used to see 80 degs at time if the stages where 12 miles, then off the stage straight into another, its like trying to set off with the handbrake on slightly.
with it before the throttle plate most of the heat is kept in the plenum, away from the sensor.
though we did find we needed to recalibrate a few other settings to compensate for the distance away.
HTH
Old Dec 8, 2009 | 09:07 PM
mechanic28's Avatar
mechanic28
HTH
interesting to know!
Old Dec 8, 2009 | 09:11 PM
sygjim's Avatar
sygjim
HTH
thanks for that
Old Dec 8, 2009 | 09:26 PM
markk's Avatar
markk
no worries.
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
15
Oct 7, 2015 03:43 PM
hopper350
Sep 4, 2015 12:53 AM
