vacuum block?
Old Dec 8, 2009 | 07:53 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default vacuum block?
Does anybody know where i can get one of the vacuum blocks for a swedish plenum?
Or will it be better to get the plenum cover drilled and tapped for the vacuum hoses?
cheers
Old Dec 8, 2009 | 08:08 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
wouldnt say one's better than the other, both do the same job jus diff ways.......easier more like to jus drill an tap the 'fold and put in hose tails...
Old Dec 8, 2009 | 08:15 PM
Dicko&Vacant
its already got the big one at the back of the plenum that joins to vacuum block,suppose i could just blank that off
Old Dec 8, 2009 | 08:44 PM
vroooom ptssssh
It Wasnt Me!
Ah I see what you mean, would be easier unless the block is available?
Old Dec 8, 2009 | 09:02 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
see if rainbum will do you one, they come with his swedish plenums
Old Dec 9, 2009 | 06:54 PM
Easy to do diy a lot cheaper.
Mark RS
Oct 12, 2015 06:01 AM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
