xr3i to ka
Old Nov 27, 2009 | 04:05 PM
xr3i_boy's Avatar
xr3i_boy
Default xr3i to ka
i have a rotten xr3i mk5 130ps and i have a ford ka with fubar gearbox
i was wondering if there was a way i cam make my xr3i engine fit and run in my ka?
if its a easy job or not?
and what will i need to make it work?
also can i use my mtx75 gearbox??
thanks fellas
Old Nov 27, 2009 | 04:13 PM
Hobomassiv's Avatar
Hobomassiv
MT dont fit IB5 can be used.
Trackdesigns do a bolt in mount.
Old Nov 27, 2009 | 04:26 PM
xr3i_boy's Avatar
xr3i_boy
there's deffo no way of running a mtx75?
Old Nov 27, 2009 | 06:21 PM
Pob's Avatar
Pob
Fairly sure the box is too long, so that would mean cutting chassis leg off/out.
If you downgrade to the ib5 box, you only have to change the flywheel/clutch assembly.
p.s make sure if your starter is at the back/front. It may cause your problems.
Where you at? I've a spare ka box, not been used in a few month but was removed from a working car. (unless you wanna sell the ka?)
EDIT, noticed your location.
Old Nov 27, 2009 | 06:36 PM
xr3i_boy's Avatar
xr3i_boy
i m not sure if i would sell the ka i might if i can find a easy car to put my zetec and box in
what about fitting the engine and box into a mk1 fiesta??
Old Nov 27, 2009 | 08:13 PM
Pob's Avatar
Pob
I'm sure others will tell you better, but your gonna have issues with the mtx box in a small front wheel drive car.
I think on zetecinside.com, he said he had to cut the chassis on a mk1 fiesta for a standard bc box!
For the Ka there's myka.org and fk-oc.com and for the fiesta there is xrtwo.com
I think fitting the zetec into the Ka is pretty straight forward, there's plenty advice/guides to guide you.
Good luck
Old Nov 27, 2009 | 11:30 PM
xr3i_boy's Avatar
xr3i_boy
iv looked on myka il look om fk-oc now thanks
Old Dec 2, 2009 | 03:13 AM
a__zed's Avatar
a__zed
Yeah can be done. There's a few threads around but call joey at trackdesigns and he'll give you a run down most likely. Mine's being fitted with an ST170 lump at the moment and I just took the LSD out of the series 2 box and stuck it in the Ka IB5. Apparently it's not that bad a box either
Aaron
Old Dec 6, 2009 | 04:12 PM
mozzy's Avatar
mozzy
Ford for life
my friend simon has a 2.1 zetec turbo 4x4 ka. anything is possible. I have some pics somewhere
stephenb4506
33
Oct 2, 2015 06:25 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
