Last bits of YUM 24/2
[B]Engine,this is a stroker 2.155cc and has steel rods and crank, liners, 8-4-1 compression, spray oil jets, WRC head gasget, modded water pump, long stud, Modded head, Solid lifters with M A Developments cams only covered 2k of miles and most of that has been running in milage, also comes with Power stearing pump, alternator, waterpump, thermostat, big wing sump. 9K
Some pictures of the build
SOLD DEPOSIT TAKEN
Front Side Lights Pair £20
Front Drive Shalf N/S £100
Rear Prop £150
Rear Prop Donut £50
Standard spare dashboard £100
Headlining £120
6 point Harness Pair in Blue £210
Spec-R Dump Valve £80
Chrome Bonnet stay £10
Standard Front calipers and disks with pads £200
Powerflex front shock absorber mount's new boxed £30 pair
Air Bag Modual £50
Also found this lot
The following item im not sure what they are worth
2 petrol/temp gauges both types your need to know where the lumination connection is as they are both diffrent
Rev counter, little mark above red line but you could swap face
This has a line above where it says x1000 and missing stopper
Standard Escort Cossie fitment £40
Bailey Breather £40
Small Turbo Intercooler pipe to Turbo £30
Small Turbo throttle body to intercooler pipe £30
Samco hose not sure what for £10
Set of red samco hoses £25 the lot
reserc valve £20
4x4 Gearbox linkage £30
Escort Cossie rubber that goes along plastic scuttle pannel £40
Set of clocks, no sensors will fit in Saph middle air vent £50 the lot
Escort Cossie back of seat carpet £20
Escort Cossie back of seat carpet, couple of small marks £15
Escort Cossie Rear quarter boot trim £30
Escort Cossie Sun visors £40
Escort Cossie battery side that holds the relays £30
Escort Cossie seat belt holders pair £20
Escort Cossie headlining handles £30 for all 3
SOLD DEPOSIT TAKEN
Rear Prop £150
Rear Prop Donut £50
Headlining £120
Air Bag Modual £50
Also found this lot
Bailey Breather £40
reserc valve £20
Yes they are for sale £200 pair
Sorry Sold
Sorry Sold
Done bring your cash around
Here is picture of wheels, only one wheel has a couple of marks all the others are mint, the tyres have only done 2 top speed days so loads and loads of tread
Engine
Harness
Comps
Pro alloy water inj tank
Engine
Harness
Comps
