Small turbo escos bleed valve
Old Nov 21, 2009 | 09:37 PM
cossie_mike's Avatar
cossie_mike
Default Small turbo escos bleed valve
Just bought a small turbo escos and it has a gay bleed valve, i want to remove this but dont no what i need to replace it on a small turbo
Thanks
Mike
Old Nov 21, 2009 | 10:30 PM
cozmeister's Avatar
cozmeister
More boost Igor!
At the very least, you want to plumb the amal valve back in.
If the amal valve is still present, plumb it into the mains, plumb the inlet manifold into one side of the amal valve, and the actuator into the other side. The Escos has a different amal valve to a Sierra, so make sure you get one of those.
Then send the bleed valve to one of those pikey metal merchants on TV like wewantyourgold.com.
Old Nov 22, 2009 | 09:04 AM
cossie_mike
Thanks for that
wewantyourgold.com lmao
Old Nov 22, 2009 | 11:36 PM
cossie_mike
I need a amal valve for a small turbo
Old Nov 23, 2009 | 12:19 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Your wish is my command:
http://cgi.ebay.co.uk/Escort-Coswort...#ht_500wt_1182
Old Nov 23, 2009 | 09:46 PM
cossie_mike
Originally Posted by cozmeister
Thanks for that cozmeister
Just been round to Divas and picked 1 up from him
Thanks Diva
Matt Baxter
Sep 16, 2015 08:30 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Cosnada
Aug 27, 2015 09:15 AM
IAN RS2k
Aug 18, 2015 07:51 PM
jay030787
Aug 17, 2015 06:16 PM
