3 door question?
dose any one else on here with a 3 door think there rad is a bit swinging in the wind .With it only having the 2 bolts in the middle section
can this be combated
as now my 500 cooler is in, there is movement on both items (rad,Cooler) due to the rubbers and sleves not allowing to nip the brackets up(to take any shock vibration i presume)meaning they could knock together,thanks in advance
Originally Posted by Alps Pacino
i think there designed to move a bit thats why there mounted on rubber, stop the alloy cracking
that i see to Alps, but the 500 cooler is mounted on the same type of rubbers and the potentiol is there for the 2 objects to rub and touch each other,the 5oo cooler is also as good as tight to the underside of the slam pannel .seems just a bit tight
where you from then alps ,dont say BORO that i see
not sure really must be right i suppose i have a radtec one on mine it touches the rad so both squash together and dont move if you know what i mean try moving yours back a touch against the rad might help, i see your from the boro to
that would be fun hiting the pullys
,by 4 bolts you mean the 2 on the rad and 2 on the cooler .The 4 location bolt holes on the 3 door are pre drilled and tapped so i cant move owt any how
,by 4 bolts you mean the 2 on the rad and 2 on the cooler .The 4 location bolt holes on the 3 door are pre drilled and tapped so i cant move owt any how Trending Topics
Hi mate I had a similair problem but noticed that the 500's have 2 extra brackets mounted at the top of the radiators and intercooler, this spaces them out from each other and bolts them to the front slam panel as well, I dont have pics of them at the moment but if you need I can post the pics up tomorrow! I fitted one of the brackets and it has made a huge difference!
Nick
Nick
i can only thik of 1 way to get it fastend tighter on the 2 retaining bolts into the chasis(spl) and that would be to shorten the sleves between the rubers allowing for more turns on the bolt,maybe my rubbers are just a bit old
Tried this before as well mate but then the intercooler sits too high and hits the under side of the slam panel! try Some of the breakers on here for the bracket as they have broken a few RS500 and may still have the brackets I am on about! honestly they do make a big difference!
Nick
Nick
andrewmctiernan
Sep 8, 2015 03:05 PM
Adam Graham
Sep 6, 2015 06:04 AM
but i was told if you fit a turbo cooler that sits on top the 500 intercooler it does have mountings to stop in moving, anyone got one fitted???????
