Advice/help wanted with RST brakes
Old Dec 29, 2004 | 07:35 PM
Lee Reynolds's Avatar
Lee Reynolds
Default Advice/help wanted with RST brakes
ok guys if ya can help id be gratefull
Right i wanna do a rear disc conversion first! I know i need the brackets(ZOO probs), then is it a rs2000 hanbrake cable? Cossie 2WD Calipers and discs??????
Then i want to use cossie front discs with my calipers. What discs? Again is it 2wd ones and another bracket??
Old Dec 29, 2004 | 07:59 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Hi Lee
People use the 2wd Cosworth disks with S2 calipers, I am doing this myself shorty, I believe MikeR and MadForIt sell the brakcets (MikeR does them as a complete kit inc washes/HT bolts).
Hope this helps bud
Edit to add i dont know about the rears, the above is about the fronts!
Old Dec 29, 2004 | 08:03 PM
PhilM's Avatar
PhilM
Lee, these links may be of use! Courtesy of Clint from Turbosport.
Cossie Front Disks - S2 Calipers
Cossie Rears
CliffRS4's Avatar
CliffRS4
Get an ST170 setup on the front as they can be picked up for peanuts
Old Dec 29, 2004 | 08:04 PM
essexrsturbo's Avatar
essexrsturbo
you can also find the brackets on www.zetecturbo.com for the rear disk and 2wd calipers
Old Dec 29, 2004 | 08:25 PM
Lee Reynolds
Thankyou kind sirs
original
Apr 28, 2026 05:20 PM
Billy_RS
16
Oct 11, 2025 09:41 PM
moesin2005
Jan 23, 2022 06:28 PM
dlwarrior
Aug 5, 2015 10:19 AM
adriansaleem
Aug 3, 2015 11:21 AM
