winter mods nearly complete
Bloody to cold to be playing with the car but you keep putting it off and then enjoy doing it when you get started, put in an AP organic clutch and a big valve head with a 285t2 cam. On the to do list is rear wishbones with poly bushes and the front cossie brake conversion, after this its completey as i want it after 8 years of ownership.
Rolling road in the new year looking for 200 bhp
TTFN PaulT
TTFN PaulT
Standard compression 0.5 over bore, 36mm exhaust valves 42mm inlets, 285t2, vernier, fuel modded metering head, stage3 turbo, modded charge cooler, scorpion exhaust, spikes at 18 psi holds 16psi, just fitted an organic clutch so should be at the rollers soon. All bread and butter bolt on bits so fingers crossed.
TTFN PaulT
TTFN PaulT
Kiran1600E
11
Oct 2, 2015 11:35 AM
Steve Escos
Oct 1, 2015 06:57 AM
