focus poly bushes for wishbones
Old Nov 17, 2009 | 06:08 PM
airzfocus's Avatar
airzfocus
Default focus poly bushes for wishbones
finking about fitting a set of these to my wishbones as the rear ones always seem to have play in them.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
they any good n how easy to remove/fit, cheers
Old Nov 18, 2009 | 11:37 AM
Sp3no's Avatar
Sp3no
You cant go wrong with poly bushing your suspension componants. You will notice a difference for sure, less tyre wear etc. I would polybush the whole arm and do the front bush's also. Bear in mind that the two bolts holding the arm on are NOT re-usable, you need new bolts and you have to tourqe them up and angle tighten them in stages. Its just a case of removing the bottom ball joint and supporting the hub and then removing the bolts for the arms, which are mega tight.
Old Nov 18, 2009 | 04:31 PM
airzfocus's Avatar
airzfocus
nice one m8, just the advice need! wots angle tigten never heard of that before? and do you know where i can get the bolts from? cheers
rex647
Mar 6, 2022 06:20 AM
155lee
Oct 27, 2015 04:55 AM
pabloXR
Sep 21, 2015 12:42 PM
richierich1986
Sep 18, 2015 03:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
