Various Cosworth Parts
Some parts from my original thread still available. Will eventually put on ebay, but thought i'd bump them back up one last time.
I will not ship these parts overseas. Parts can be collected from Leamington Spa in the Midlands, otherwise we will need to agree postage and packing.
New CompBrake Compression Strut Kit – never fitted with 2 sets of body brackets with different pitch spacing – £120
ABS Brake Master Cylinder & Actuator Assembly, Modulator and ECU – will also supply harness without wheel speed sensors, but one speed sensor lead is damaged - £60
Genuine Ford Engine Mounts – Used for no more than 100 miles - £80
Group A Coil, Ignition Amplifier & Silicone Leads - £50
GGR Lucas Refurbished 3dr/2wd Power Steering Rack – New! Fitted but never used! – £120
Reservoir & Bracket – £20
Steering Column Cowl & Stalks – One of the tabs has broken off the lower cowl as seen in the photo - £30
3dr Fog Lamps – not cracks just some very small stone chips - £20
3-spoke Steering Wheel – Was sold on ebay but never claimed.
I also have a set of std 3dr wheels in good condition. Centre caps & locks (no key) which need refurb. Fitted with R888 tyres with half their life left - £400
interested in coilovers if you still have them ????? ,just curious though can you confirm that the bottom coilover in your picture is not bent ???
just looks like its bent may just be the pic ??
cheers
cheers
Hi, The unit is not assembled properly and the spring is loose and sat at an angle making it look bent. You should be able to see the piston rod is straight in the pic if you look through the spring. Cheers
HI if the other Gaz suspension legs are as good as the one in the picture and they are the Gold not the standard ones and i asume they are in good order please put my name on them give me a call and we can discuss how to pay etc
Thanks
Mark
07854766174
Thanks
Mark
07854766174
Any chance of closer pics of the fronts?
3dr cossie
11
Dec 21, 2015 03:38 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
