Ford Puma Discuss the Ford Puma here!
Puma clutch problem please help
Old Nov 16, 2009 | 07:50 PM
cool head's Avatar
cool head
Default Puma clutch problem please help
Ford puma 1997 1.7.
So I was going for a ride and started in 1. - 2. - 3. and I slowed down for a turn, stepped on the clutch-pedal and braked... the car slowly died..
As i lift my foot I notice that the clutch-pedal stays in the pressed 'in position.
I tap the pedal a few times and it springs back to normal lifted position, I then step on the clutch-pedal, start the car, and shift it into 1 which results in a BOM and the car is "choked" again... lift my foot and the clutch is stuck again.
So after a bit of tapping the clutch i manage to get the car moving and notice that all the clutch "action" is concentrated around the area where the clutch-pedal is almost pressed all the way down..
I drive for a little while then stop for a couple of minutes and turn the car off..
On my drive home again the clutch feels normal...
Please help.. Really really frustrated!?
Best Regards Lasse D
Old Nov 17, 2009 | 06:53 PM
crazyshad1's Avatar
crazyshad1
do they have a ratchet adjustment on the pedal? i had a renault 5 gt turbo and the teeth on the ratchet where worn so the pedal would sometimes go straight to floor when pressed, i had to lift the pedal up to reset the ratchet
Old Nov 17, 2009 | 07:26 PM
rs tingle's Avatar
rs tingle
its a hydrolic clutch on the pumas it will probley have aire in the system or ya need a new thrust bearing i did one on my friends car i changed the clutch too its a right pain to do. defo sounds like there is air in the system
Old Nov 19, 2009 | 08:21 PM
cool head's Avatar
cool head
thanks for the answers.. I will try replacing the bearing.
yatta
May 21, 2016 10:31 PM
Rammer46
Sep 18, 2015 08:31 AM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
Ben26
Sep 3, 2015 07:55 PM
