hello
Old Nov 16, 2009 | 01:31 PM
coolj's Avatar
coolj
Default hello
hello ever one iv just got myself an st24 and need sum help with it as i dnt no any think about them
Old Nov 16, 2009 | 01:52 PM
Hello LL coolj whats wrong with it.
Old Nov 17, 2009 | 01:54 PM
coolj's Avatar
coolj
hi mate its not got alot of power it feels like an auto it takes it time 2 get the power there and i think there is sum think wrong with the throttles
Old Nov 17, 2009 | 02:03 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Try in here
https://passionford.com/forum/ford-st-and-xr-range-48/
Steve
Old Nov 17, 2009 | 02:13 PM
Brian ST-2's Avatar
Brian ST-2
Standard problem are the secondaries in the inlet manifold.
Just thought I'd reply in here as this is where the query started, and happened on mine.
Once that's sorted you should be fine, oh and maybe get the IMRC ( think that's what it's called ) sensor moved from the manifold to over by the battery to prevent heat soak.
Failing that, put note up in the ST room as above.
Brian
Old Nov 22, 2009 | 11:04 PM
coolj's Avatar
coolj
thanks mate iv got a cable cuming off the top throttle linked 2 the bottom one but when i look at other st24 they dont have it
