How to remove old tape residue from your bumper
Old Nov 15, 2009 | 02:55 PM
392B.H.P.SAFF's Avatar
392B.H.P.SAFF
Default How to remove old tape residue from your bumper
Have been soaking it with wd40 for the last few hours but it is really coming off slowly and i havn't done the back plate yet???
What do you use to remove the old double sided tape???
Old Nov 15, 2009 | 02:56 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
Hairdryer to warm it up then t-cut/some other polish.
Old Nov 15, 2009 | 02:58 PM
Dicko&Vacant's Avatar
Dicko&Vacant
you can get a wheel that goes on a drill think its called a caramac wheel?
Old Nov 15, 2009 | 02:59 PM
392B.H.P.SAFF
Will go and get the Mrs hairdryer and try it.
Trying to fit my new plates
Old Nov 15, 2009 | 03:04 PM
Oranoco's Avatar
Oranoco
AutoGlym tar spot remover wprks well. When I worked in retail I obtained a bottle of Point Of Sale gum remover which shifts sticky muck without a trace.
Old Nov 15, 2009 | 03:07 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
nitromors and a wire brush.
Old Nov 15, 2009 | 03:10 PM
gazz king's Avatar
gazz king
hi ya, i used to remove the stickey with unleded petrol,
get a rag and soak it in the fuel and wipe the glue give it a good soak over ten minutes
and then have a go at wiping it off,
and this wont hurt your paint,
man do not ese thiners thow, i found out the hard way lol
Old Nov 15, 2009 | 03:46 PM
dazoriginal's Avatar
dazoriginal
prodigal son
thinners works if your carefull !!
Old Nov 15, 2009 | 03:59 PM
392B.H.P.SAFF
Have finally removed all the old residue from the front bumper i used Autoglym tar spot remover then just some old polish and both worked well,, will drag the motor out from the garage tomorrow and do the same for the rear number plate.
Thanks for all you reply's
Orion_Gav
Sep 29, 2015 04:50 PM
rsguy
44
Sep 29, 2015 03:29 PM
