printed circuit bored
Are you on about the flexi pcb on the outside at the rear of the clocks, or the pcb on the tacho ?, think I may have misunderstood.
If it's the flexy one on rear, then same across sierra range(mk1 and mk2 same), apart from some have a rev counter that has pins that go through the holes in the strip where they poke through the rear of the clocks and some have nuts.
SMILER258
Sep 28, 2015 09:04 AM
