Help needed Focus st170 gearbox convertion
Old Nov 13, 2009 | 10:47 AM
Tank Mike's Avatar
Tank Mike
Default Help needed Focus st170 gearbox convertion
Do the bolt up to an rs engine with the rs clutch??
And do they bolt on the same mounts as a normal 2l focus box.
im not worryed about the management side of things as i have omex
cheers
Old Nov 13, 2009 | 12:36 PM
Tank Mike's Avatar
Tank Mike
bttt
Old Nov 13, 2009 | 01:00 PM
FOCUSTARD PIE's Avatar
FOCUSTARD PIE
cheers
I used the STclutch and flywheel, bolts on same mounts.
Thats on a 2.0 duratec RS focus engine !
Old Nov 13, 2009 | 01:08 PM
Tank Mike's Avatar
Tank Mike
cheers mate, will the rs clutch fit the st box do you know?
amd do the rs shafts fit the st gearbox
what did you do about gear cables ect.
cheers mate
Old Nov 13, 2009 | 01:19 PM
FOCUSTARD PIE
cheers mate
RS clutch would'nt fit. when i went over 300bhp had to change to a paddle clutch.
Used st shafts, cables and gear selector.
Kev
Old Nov 13, 2009 | 01:25 PM
Luca's Avatar
Luca
Lukesville
As above...
The st170 is unique so clutch/flywheel and shafts will not fit anyother box and vice versa.
You need to run st170 clutch/fly standard or uprated... if uprated look from USA they call it SVT rather than ST170
Gear selector cables and stick you need st170 too!
Shafts again you need st170 set up and if using zetec block you need the sump pan as the half shaft mounts to this...
If your using cvh engine still you need to make a mount of block for the half shaft!
Old Nov 13, 2009 | 01:34 PM
Tank Mike's Avatar
Tank Mike
well theres my cheap stong gearbox out the window then!
bloody van! lol
thanks for all the advice guys
Old Nov 13, 2009 | 02:52 PM
Luca's Avatar
Luca
Lukesville
Your best bet is run with a Focus Rs one then.
Palethorpe01
15
Aug 18, 2015 06:09 AM
track.focus'd
Aug 12, 2015 05:53 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
