141 bhp fiesta zetec s (PERFORMANCE FORD FEATURED MAY 2010!!!!!)
Hello guys and girls .im new to the site so i thought i would start a project,
the spec is:-
Engine:-
the spec is:-
Engine:-
- 1.6 16 valve shawspeed tuned engine
SS4 high lift cams
ARP heavy duty big end bolts
1.7 puma inlet manifold
MSD super chip mapped to SS4 spec with the rev limiter mapped off
Omex rev limiter set at 7800rpm
Omex launch control set at 4000rpm
Magneco HT leads
Pipercross panel filter
4-2-1 milltek sport evo manifold
Milltek decat pipe
Custom cat back system with duel exit oval tail pipes
Custom cold air feed to air box
Full blue samco hoses
Engine dress up- jenvey DTH 42mm bodies(soon to be fitted)
- Helix organic clutch
- Helix pressure plate
- ShawSpeed lightened and balanced flywheel
- Stripped and painted rear
Show cage
Cobra monaco pro bucket seats
Cobra sub frames
3 point cobra harnesses
Chrome rear strut brace
Nu-suede door cards
Nu-suede A pillars
Nu-suede boot cover- Nu-suede glove box
- Nu-suede vent surrounds
- Nu-suede fuse box cover
- Nu suede air bag cover with omex 600 mounted in it
Blue dial and dash conversion
Ford racing puma steering wheel
Puma gear knob painted blue numbers
Omex launch control mounted on dash
6x9 speakers mounted in rear quater panels on custom frames
Alcantra gear and handbrake gaitors
Custom floor mats
Fluffy hand cuffs
- Custom mk5 bonnet with mk4 rs turbo bonnet vents sprayed gloss black
Roof and roof rails sprayed gloss black
Gloss black spoiler
Front grill surround sprayed gloss black
Gloss black door handles
Gloss black mirrors
Gloss black front and rear bumper strips
Gloss black lower grill and bumper lip
Side strips removed
Smoked ultra front lights
Freestyle grill
Black fog lights
Smoked side repeaters
MHW rear lights(defiltered)
Ford logo mud flaps
Smoked wind deflectors
Smooth boot handle
Debadged boot lid
Private number plates
Bonnet raisers
- AP sport coilover kit lowered approx 60mm
OMP lower strut brace
e-tec front upper strut brace
57mm chrome rear strut brace- Vibr technics gear box mount
- Mondeo mk2 2.5 v6 280mm callipers
280mm discs
green stuff pads
dot 4 fluid
- Genuine escort cosworth alloys (summer wheels)
Toyo t1r's stretched
195/45/16
Standard zetec s alloys sprayed gloss black with st 170 center caps(winter wheels)
195/50/15 michelin exalto pz2's
Hello guys and girls .im new to the site so i thought i would start a project,the spec is:-
Engine:-
1.6 16 valve shawspeed tuned engine, SS4 high lift,cams ARP heavy duty big end bolts 1.7 puma inlet manifold MSD super chip mapped to SS4 spec with the rev limiter mapped off. Omex rev limiter set at 7800rpm, Omex launch control set at 4000rpm.
Magneco HT leads,Pipercross panel filter,4-2-1 milltek sport evo manifold,Milltek decat pipe and Custom cat back system with duel exit oval tail pipes. Custom cold air feed to air box,Full blue samco hoses.
Interior:-
Stripped and painted rear,Show cage Cobra monaco pro bucket seats,Cobra sub frames3 point cobra harnesses.
Chrome rear strut brace, Nu-suede door cards, Nu-suede A pillars,Nu-suede boot cover.
Blue dial and dash conversion, Ford racing puma steering wheel,Puma gear knob painted blue numbers. Flocked dash parts,Omex launch control mounted on dash.
6x9 speakers mounted in rear quater panels on custom frames,Alcantra gear and handbrake gaitors,Custom floor mats and Fluffy hand cuffs
Exterior:-
Custom mk5 bonnet with mk4 rs turbo bonnet vents sprayed gloss black,Roof and roof rails sprayed gloss black,Gloss black spoile,rFront grill surround sprayed gloss black.
Gloss black door handles Gloss black mirrors Gloss black front and rear bumper strips,Gloss black lower grill and bumper lip.
Side strips removed,Smoked ultra front lights,Freestyle grill,Black fog lights,Smoked side repeaters,MHW rear lights(defiltered)Ford logo mud flaps.
Smoked wind deflectors,Smooth boot handle,Debadged boot lid,Private number plates,Bonnet raisers.
Suspension:-
AP sport coilover kit lowered approx 60mmOMP lower strut bracee-tec front upper strut brace57mm chrome rear strut brace
Brakes:-
Mondeo mk2 2.5 v6 280mm callipers,280mm discsgreen stuff pads,dot 4 fluid
Wheels and tyres:-
Genuine escort cosworth alloys (summer wheels)Toyo t1r's stretched 195/45/16
Standard zetec s alloys sprayed gloss black with st 170 center caps(winter wheels)195/50/15 michelin exalto pz2's
Engine:-
Interior:-
Exterior:-
Suspension:-
Brakes:-
Wheels and tyres:-
It is no doubt completely grammatically incorrect but meh i couldnt care it was just a nightmare to read.
We need some pics of this car as well, project sounds great
Ginge
here are a few pictures of how it stands today... i bought the car from bog standard and have had alot of work done by myself and others
SDC14824.jpg?t=1258211463
SDC14856.jpg?t=1258211496
SDC14828.jpg?t=1258211517
SDC14827.jpg?t=1258211544
SDC14896.jpg?t=1258211570
SDC14891.jpg?t=1258211597
DSC00048.jpg?t=1258406748
only one i got
SDC14933.jpg?t=1258406818
a set of jenvey 45mm trumpets ready to be attached to a set of jenvey dth throttle bodies next year
only one i got
as im going to be fitting throttle bodies in the new year i got in contact with jon at shawspeed last night and ordered a few things....
next will be the actual jenvey dth bodies and omex 600
- throttle position sensor
- air temperature sensor
- coolant temperature sensor
- upgraded fuel pressure regulator
- injector blanks
my mate has a 170bhp civic and we came off the round about and he was on the inside lane i was coming round him till i hit the 6700rpm limiter
got my new chip now and i think its reving to 7100rpm still not peak power but i dont want to raise it anymore incase im doing something wrong!
i will wait till track and road set it up correct at 7800rpm :P
hello
thanks fella
you need to drill the hub holes out with a 12mm bit!
then fit 3mm spacers behind the discs so the disc clears the abs rings.
you can also fit a 300mm kit but the calipers and carriers need to be shaved to clear 15" zetec s wheels
decided to order more little things today! im addicted to oredring parts for the car lol
i ordered....(all from shawspeed) top service!
Omex programming kit
Connectors for management loom
3 metres fuel pipe c/w 6 off clips
Vacuum pipe adaptor
Vacuum pipe adaptor
i have been thinking over the last few days on another one of a kind mod,finally found the item i wanted so waiting for that to arrive then im going to take it from there,should be a nice touch once done, im not reveling what just yet as im unsure on what will happen if i can pull it off and what it would look like
decided to scrap my mod!got a few issues with spluttering today!!
the car is realy hesitating and popig a spitting flames like mad haha!
i pushed the ht leads on and every thing seems to be fine,so tomorrow im going to take plugs out and have a look see whats up
all seems fine now with the car
been and ordered some more goodies again from shawspeed :P
i also found out the other day that i need a new gear box mount as its almost touching the lower strut brace
so a VT shall be on order soon as i get payed
went up the garage yesterday and stripped the old engine mount off(major ball ache)
and its fubar
so another one is on order and will be here in a few days,
also found out where to top my gear box oil as im losing a small amount every so often so im happy with that
now the car is off the road some bufty action can go on :P
and its fubar
just been up the garage in the freezing cold
topped up my gear box oil and had a check around the car, what i did notice was alot of water around the spark plugs! i think its coming from the bonnet vents so dried it all up and sprayed it all with WD40, so going to see how it goes.
while im bored in the house i started to polish up my ITB trumpets ready looking alot better already pics to follow
