nearly stalls when I dip the clutch ?
Old Dec 29, 2004 | 10:21 AM
220TC's Avatar
220TC
Default nearly stalls when I dip the clutch ?
Hi,
Recently I have noticed that when I dip the clutch when I come up to a junction the revs will drop really low for a split second & nearly stall but then they rise up to the normal 900 rpm. Also it 'hunts' a bit, not all the time though. Anyone have any ideas what could be causing this ?
cheers, Duncan
Old Dec 29, 2004 | 10:28 AM
KSA-Cossie's Avatar
KSA-Cossie
Mine did that a while back,spray some carb cleaner into the air intake.
Old Dec 29, 2004 | 10:58 AM
220TC's Avatar
220TC
did it cure it then
Old Dec 29, 2004 | 01:24 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
cld be iscv on its way out, or check no leaks from vacum pipe that comes from servo to inlet. or for any other vacum leaks.
Old Dec 29, 2004 | 01:49 PM
220TC's Avatar
220TC
is this the throttle position sensor
Old Dec 29, 2004 | 01:52 PM
KSA-Cossie's Avatar
KSA-Cossie
did it cure it then
It did cure it.
Old Dec 29, 2004 | 01:53 PM
KSA-Cossie's Avatar
KSA-Cossie
Erst doesn't have an iscv.
Old Dec 29, 2004 | 03:35 PM
vroooom ptssssh
It Wasnt Me!
What kinda ERST u got? It does, here it is here:
Old Dec 29, 2004 | 03:37 PM
vroooom ptssssh
It Wasnt Me!
Nope Idle speed control valve. the thing in the pic ive circled.
Old Dec 29, 2004 | 03:44 PM
KSA-Cossie's Avatar
KSA-Cossie
Thats an auxiliary air valve david me boy.
Old Dec 29, 2004 | 03:50 PM
vroooom ptssssh
It Wasnt Me!
Yup, but still does the job of an ISCV
Old Dec 29, 2004 | 03:53 PM
KSA-Cossie's Avatar
KSA-Cossie
Just ain't called one though,if a cat is born in a kennel it isn't a dog is it . lol.
Old Dec 29, 2004 | 04:02 PM
vroooom ptssssh
It Wasnt Me!
Theirs always one smart arse
Old Dec 29, 2004 | 04:03 PM
KSA-Cossie's Avatar
KSA-Cossie
Old Dec 31, 2004 | 08:50 AM
ldack's Avatar
ldack
My ERST did that a few weeks ago, and it was the sump gasket leaking.
Have got a slight prob now though - if anyone can help. Tickover seems to be a little high, and didnt use to be - any ideas?
Old Dec 31, 2004 | 09:34 AM
KSA-Cossie's Avatar
KSA-Cossie
Turn it down a bit.
Old Dec 31, 2004 | 01:35 PM
MK5RST's Avatar
MK5RST
As above
Old Jan 1, 2005 | 01:10 PM
AJC's Avatar
AJC
Old Jan 1, 2005 | 03:13 PM
vroooom ptssssh
It Wasnt Me!
Turn it down a bit.
Problem dodger
Old Jan 1, 2005 | 05:01 PM
KSA-Cossie's Avatar
KSA-Cossie
Soap dodger lol.
Old Jan 1, 2005 | 09:00 PM
vroooom ptssssh
It Wasnt Me!
half a bumper (cheepskate) lol
Old Jan 2, 2005 | 12:19 AM
KSA-Cossie's Avatar
KSA-Cossie
Least i can drive my car!!!!!!!! lol.
Old Jan 2, 2005 | 04:32 AM
vroooom ptssssh
It Wasnt Me!
erm, least mines not putting miles on
Old Jan 2, 2005 | 10:24 AM
KSA-Cossie's Avatar
KSA-Cossie
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
