Water Leak on Saph??
Hey All,
Im new to the cossie owners group, just a need a lttle help before i climb under her tomoz.
Went out to her this morning, and warmed her up for 10 mins before going out, to notice a bit of water running from underneath, opened the bonnet, seems to be leaking from the waterpump area. Now does this mean the waterpumps fooked???
Cheers in advance
Steve
Cheers in advance
Steve
Is it 2 or 4WD?? Theres a little short hose that links the stat housing and waterpump on the 4WD's (Maybe on 2WD's too?) If not, theres a pipe from the water pump, to a metal pipe on the bottom of the rad. Both went on mine, just pissed water out from the water pump area...
Good luck with it...
Mark RS
Oct 12, 2015 06:01 AM
