Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
i need some urgent help??
Old Nov 1, 2009 | 11:48 PM
Rs25-ROSS's Avatar
Rs25-ROSS
Default i need some urgent help??
i have just bought a mk5 cabby with an rs2k motor in! while driving i have a vibration or judder come from the passenger side? Cant figure out what it is the tie rods, track control arms, and ball joints are new what could it be?
Old Nov 1, 2009 | 11:57 PM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
i have mk5 had 5 mk6 SI's i had same on two ocasions once mk5 and once mk6 all the same they suffer from .... wish bone , wheel bearings and staibalizer bars change both front sides and check both sides for tracking this might help and parts are very cheap ,.,.
Old Nov 2, 2009 | 12:02 AM
Rs25-ROSS's Avatar
Rs25-ROSS
I had wheel bearings checked and they are like new could it be a nearside driveshaft as mine has play in it? Everything else has recently been replaced now i have looked through receipts
Old Nov 2, 2009 | 12:22 AM
benjaminsarmy
if you can fix it its not hard to fit just do anti roll bar bush both sides does it pull you all over the road on and off the power
Old Nov 2, 2009 | 07:01 AM
Rs25-ROSS's Avatar
Rs25-ROSS
no it doesnt pull me all over the road it just judders like hell on acceleration
Old Nov 2, 2009 | 09:30 PM
Icurus's Avatar
Icurus
Could also be an engine mount thats worn or loose?
Can you rock the engine by hand?
The usual culprit is the mount thats just below the brake servo.
Old Nov 2, 2009 | 10:38 PM
Rs25-ROSS's Avatar
Rs25-ROSS
all sorted it was a driveshaft
DaveN
13
Jan 9, 2005 06:19 PM
R4N SS
Jan 1, 2005 12:17 AM
Walshy
May 14, 2004 01:34 PM
