High Power FWD and Traction...
Old Dec 27, 2004 | 11:31 PM
MadMac's Avatar
MadMac
Default High Power FWD and Traction...
So been thinking this over. Oranoco has 248bhp on his S2. But he has little to no traction in 1st and 2nd....
now you can overcome this by better quality tyres and wider rims and all that but you can only go so far with that.... so how can you improve traction on a FWD without having to cut arches for silly thickness drag rims on the front of the car
Ideas?
Old Dec 27, 2004 | 11:32 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
raise the rear the car
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
There really isnt alot you can do. Learning the car is about the best you can do.
Wider wheels/tyres will give better traction, but will make it handle like shit. So its all a compromise.
Old Dec 27, 2004 | 11:33 PM
Christian and Beccy
#1 in Spelling Club
Drastic nose-down does help.
I tried -40mm Front, Standard Rear. It gripped like fook, but looked really shite!!
Old Dec 27, 2004 | 11:35 PM
Charlie Chalk
Unknown.
does look shit i know but helps
Old Dec 27, 2004 | 11:36 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Fitting a three piece driveshaft setup (Equal length outer shafts no torque steer) with an MTX75 is about the best you can do IMO
Old Dec 27, 2004 | 11:37 PM
MadMac's Avatar
MadMac
Ahh now that sounds promising... got any more info?
Old Dec 27, 2004 | 11:41 PM
Versus_Creations
Ask me a question!
https://passionford.com/forum/viewtopic.php?t=92213
Old Dec 27, 2004 | 11:48 PM
MadMac's Avatar
MadMac
Old Dec 28, 2004 | 12:59 AM
Paul J's Avatar
Paul J
There are FWD cars faster down the strip than any 2wd cossie on here and prob 4wd too, there's plenty to it (drag tyre's are needed tho) , DannyB is your man.
Old Dec 28, 2004 | 01:30 AM
NUTS RuS's Avatar
NUTS RuS
As it accelerates the front of the car lifts up losing traction under the wheels (hense lifting the back up slightly to limit this helps) One of the more efficient ways to stop it doing that is by trying some suspension mods. Stiffer springs and different damper rates and heights all have some effect. Then as above tyres will help with grip, then the way the drivetrain distributes the power must have some effect too There are ways it just costs time and money Iv'e spent hours and hours just playing, but dont have a HIGH POWER car
Old Dec 28, 2004 | 09:26 AM
S1's Avatar
S1
As Christian said a car set up for drags handles like a bag o shite. This seems to be the downfall of most of the RST's I have seen in that they are set up to look good ie low all round. That obviously doesnt help drags. I ran my FRST at the recent PF Brunters bash with coilovers on the back set as high as they go, 180lb springs, and bump/rebound set full on. Front tyres are 195/50-15 so when they are set at around 14 Psi you get tyre distortion and so get maximum rubber on the road. As the front arms are rose jointed i run the tracking set between 0 toeout to 1mm toeout.
I am currently waiting on a full coilover set from Leda with narrower front bodies so I can run a 205/50-15 soft compound road legal tyre. This will be corner weighted for two set-ups, drag and cornering and the positions marked on the bodies so I can switch between the two when required.
Old Dec 28, 2004 | 09:33 AM
Ginge !'s Avatar
Ginge !
just finding my feet
or just dont side step the clutch like oranoco
he loves the wheel spin tbh, he can drive for traction but hes very much into top speed
just learn to drive the car and get how it feels and see how ya like it
ya dont wana have a car thats wicked in a straight line as there aint many on our roads and tbh all ya gotta do is balance the accelerator
its not a on off switch
Old Dec 28, 2004 | 09:34 AM
Ginge !'s Avatar
Ginge !
oh forgot steve has got a small zorst housing so his full power comes on earlier than most erst's
when he gets off his lazy arse and fits his .48 or .63 ( cant remember what one) he will have a bit less wheel spin as it will have a tuny bit more lag allowing the power to be stuck down
Old Dec 28, 2004 | 09:35 AM
Ginge !'s Avatar
Ginge !
but then ya gotta deal with torque steer as steves is a fooker for that
but again he loves it so he never changed it
gus's Avatar
gus
i have just got the turbo smart boost controller
this has different boost settings for different gears, hopefully this will work a bit better, also gone for a t34 so this shouldnt spin up quite as fast as me last turbo
all else fails back to throttle control
Old Dec 28, 2004 | 09:41 AM
Ginge !'s Avatar
Ginge !
boost controller will make it come on boost more hard
as theres no creep, just bang
back to throtttle control i belive ( or 4wd conversion )
Old Dec 28, 2004 | 11:55 AM
gus's Avatar
gus
yeah but gonna run it at a more sensible amount then the 32psi it runs at the mo
that amount is not good in the small gears
Old Dec 28, 2004 | 11:57 AM
Ginge !'s Avatar
Ginge !
really
good luck
whats the model of ios and how can it tell what gear ya in btw ????
i know my blitz can adjust boost at different speeds , but thats cause of the power meter attachement
Old Dec 28, 2004 | 12:20 PM
gus's Avatar
gus
i have no idea how it works, i just pay me money and then pick it up all fitted
i would rather not know, too many wires for me
Old Dec 28, 2004 | 12:22 PM
Ginge !'s Avatar
Ginge !
Old Dec 28, 2004 | 12:30 PM
MadMac's Avatar
MadMac
Hmmm, so boost controlers might be an option then.
Ginge, I'm a speed in a straight line man Dont have the balls to late break for corners
Old Dec 28, 2004 | 12:31 PM
My nova takes 270bhp in second gear without any wheelspin, thats mainly down to tyre choice, ATB diff and ensible suspension setup really.
Tyres are the key thing, get some inters on there.
Old Dec 28, 2004 | 12:32 PM
PS, to see just how well my car gets traction, watch the video link in my signature, you can see the front lifting slightly but not breaking traction in 2nd gear as the power is applied and no wheelspin at all.
Old Dec 28, 2004 | 12:35 PM
gus's Avatar
gus
hopefully in the next few months i will have my suspension fully sorted so thats will be out the way, down sizing wheels to a ste of 16" if i can squeeze them over me brakes
only thing is i think im very limited to tyre choice with a 16" wheel
does a firm make road legal slicks for 205 / 40 / 16
oops double post
gus's Avatar
gus
o ris it 195 / 45 / 16 that i want
Old Dec 28, 2004 | 12:38 PM
Ginge !'s Avatar
Ginge !
chip ypou saying your car has 270bhp in second gear
stu boost controllers are ok if there a programable one like what i got, a normal boost controller that holds until ya reach full boost aint gonna help as thats gonna allow ya to reach full boost sooner
learn to use the throttle
Old Dec 28, 2004 | 12:40 PM
Yes my car has 270bhp in every gear except the first one when i run it at the pod.
Ginge !'s Avatar
Ginge !
gus what brakes ya got, ya can fit anything upto 315mm discs under standard wheels if there done correctly, infact 330's can be done if ya brave
Old Dec 28, 2004 | 12:43 PM
Rick's Avatar
Rick
gus - i looked into the e boost, and although they advertise diff boost in each gear - i dont think u can adjust it.
Old Dec 28, 2004 | 12:50 PM
Ginge !'s Avatar
Ginge !
i know the appexi can but thats not ment to be good at 2bar
blitz id3 range is a nice idea but that works off the speed sender and is for different speeds not gears ,i got that one ( still in the box too , i really need to pull me finger out )
Old Dec 28, 2004 | 02:27 PM
gus's Avatar
gus
mine are 335mm discs
so will need to go down a size or two
could i just change the disc or would it be the bells and brackets too
Old Dec 28, 2004 | 02:32 PM
peteh's Avatar
peteh
what about moving the engine? over the wheels or even leaning the engine back anf forth
Old Dec 28, 2004 | 03:00 PM
puntoturbo's Avatar
puntoturbo
i'm using the the apexi avcr to control boost, it has a feature to run less/more boost in each gear.
i've dropped the boost down in 1st and slightly in 2nd so now there is no wheel spin atall in the dry.
my mate has a 300brake 200 which used to be crazy in the dry, arse end never wanted to stay planted. he was using an apexi avcr and didnt know about the start duty setting for each gear, i went out with him and setup his 1st and 2nd gear dutys and now he can floor it in 1st & 2nd with the arse end staying planted.
the apexi can also run up to about 3bar of boost
Old Dec 28, 2004 | 03:24 PM
Ginge !'s Avatar
Ginge !
the apexi aint very good after 2 bar, trust me on that
not on fords anyway
Old Dec 28, 2004 | 03:26 PM
timrud's Avatar
timrud
Traction is a serious problem in my car.....
Last time I went to the Pod, 1st and 2nd were appalling no matter what I did, and 3rd needed sensible application of the throttle. Even setting off in 2nd didn't make any diference to my 60ft time.
I've a set of coilovers on the horizon, I'm hoping they will sort a tiny bit of the problem. At the moment I have a set of the baldest tyres ever on as the car is taking a winter break, but if it rains it will spin in sixth on the motorway The camber is also is bit odd on my front wheels, which I'm sure adds to my problem.
Think I'm going to try setting off in bottom boost setting then when at about 5000rpm in 2nd flicking to the top position, in an effort to improve my 60ft times.
I really want to go out in a car with a Quaife ATB LSD to see if they make much difference
Old Dec 28, 2004 | 03:28 PM
Ginge !'s Avatar
Ginge !
how does the quaife make a difference ????
are the ratios taller ???
Old Dec 28, 2004 | 03:31 PM
timrud's Avatar
timrud
No its the same box, but an LSD that is put on it....
From what I've heard they improve traction (and can pull you through corners?) but in a straight line they like to "pull" side to side more. Well my car has more than enough torque steer already, so I don't want any more side to side action
