brake up grade
Old Oct 29, 2009 | 06:27 AM
chris turk's Avatar
chris turk
FIESTA RST BLACK
Default brake up grade
what is the best brake upgrade to do for my fiesta rs turbo anyone?
Old Oct 29, 2009 | 10:20 AM
jammerrs's Avatar
jammerrs
what size wheels have you got?
cossie disks and calipers is the usual for 15"+ wheels
Old Oct 30, 2009 | 03:20 PM
paceo's Avatar
paceo
chris, get yourself over to www.fiestaturbo.com you will find it much more use to you regarding your rs turbo
Old Dec 22, 2009 | 04:04 PM
Jur's Avatar
Jur
the 'best' options.. depends on your needs:
- Focus ST170 300mm (16/17" required)
- Fiesta ST150 280mm (15" required ... 16")
- Escort cosworth (mondeo V6) 278mm (15" required)
- RS2000 260mm (14" required)
Old Dec 22, 2009 | 08:55 PM
Brian's Avatar
Brian
I fitted Fiesta ST150 calipers and discs to my dads Fiesta RS1800 and they just about fit with 15" wheels and its stops really well now the ST150 set up bolted straight on as well can get everything you need for around £150
Brian
Old Feb 12, 2010 | 09:49 PM
DHMC's Avatar
DHMC
Brian
mate could you give us the low down on whats needed..
1.
2.
3.
etc looking to do the same conversion
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
