Cosworth "Hesitation" on light throttle problem.....
Old Oct 20, 2009 | 07:39 PM
boXXer's Avatar
boXXer
GASH!
Default Cosworth "Hesitation" on light throttle problem.....
Hi all, just wondered if anyone can help.
A mates saff has got a weird problem when your on very light throttle, like pulling away from stationary, or when, in say, 4th and 5th and your on trickling throttle in flowing traffic (like 40-50mph).
On boost, its fine, pulls lovely, no missfires, or anything. Same as when the car is on full load, i.e, say 5th car, 40mph, no boost, but foot is on the floor.
All the igntion system has been changed to a MSD stg3 chip, and MSD coilpack conversion, with new 071's gapped @ .6mm. The car did exactly the same problem on the old chip/ignition setup, so its not that.
put the car on my gunsen CO2 meter, and was originally running 12%, but got that down to 3% by adjusting the ECU. Havent checked fuel pressure yet, so need to buy a gauge.
any suggestions on what to try next?
Thanks!
Old Oct 20, 2009 | 07:42 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
set up
Old Oct 20, 2009 | 08:12 PM
boXXer's Avatar
boXXer
GASH!
Originally Posted by James @ M Developments
set up
its on the cards mate
Old Oct 20, 2009 | 08:21 PM
JTECH James
Passion for Fords!
kettles on lol
Old Oct 20, 2009 | 08:23 PM
boXXer's Avatar
boXXer
GASH!
wont be on for too long mate as my 530D is booked in next tuesday for a remap
not looking forward to the drive again
Old Oct 22, 2009 | 01:21 PM
boXXer's Avatar
boXXer
GASH!
up
Old Oct 22, 2009 | 01:33 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
i had a the exact problem you describe. Was a dodgy phase sensor connector inside the dizzy. Changed that and all was well.
Old Oct 22, 2009 | 04:16 PM
I had that, well fairly similar, was a tps, missing a tiny spot, tested 100% perfect, could not find a low/missing resistance on it anywhere, but was there just above idle on throttle and low engine speed.
When I changed ecu's, the fault became massively amplified to the extent that it couldn't even be driven through in a higher gear on the rollers, so had to put on a universal one, then perfect.
I was stunned by the difference it made on the new ecu, the L6 coped much better no doubt by overfuelling all the time.
Old Oct 23, 2009 | 06:59 AM
boXXer's Avatar
boXXer
GASH!
well, new phase sensor is on its way so we are gunna try Rich's idea first, as his one does look a bit dodgy. Will let you know if it works or not
Old Oct 23, 2009 | 08:46 PM
CossieRich's Avatar
CossieRich
Boxxer,
It wasnt the pahse sensor itself, it was the bit where the phase sensor wires plug into that was the problem
Old Oct 24, 2009 | 12:00 PM
boXXer's Avatar
boXXer
GASH!
do you mean on the dizzy side?
Old Oct 24, 2009 | 12:15 PM
CossieRich's Avatar
CossieRich
yes on the dizzy side mate
Dicko&Vacant
Aug 21, 2015 05:59 PM
Bailes1992
Aug 16, 2015 07:14 PM
Aug 14, 2015 07:29 AM
M K
Aug 12, 2015 06:57 PM
Old ford
Jul 31, 2015 06:50 AM
