Sandblasting inlet manifold? any good or harm?
Old Dec 26, 2004 | 10:59 AM
cozzie4d's Avatar
cozzie4d
Default Sandblasting inlet manifold? any good or harm?
Hi.
My planning is to let my inlet manifold and plenum we sandblasted, and than respray it in silver.
Can someone tell me if sandblasting the manifold/plenum can do any harm, as in performance, flaws or whatever?
Thanks.
Old Dec 27, 2004 | 09:40 PM
swerv's Avatar
swerv
make sure there are no 'bits' left after the blasting as i know a few people who messed engines this way
tbh , you shouldnt need to have it shot blasted just cleaned and painted??
Old Dec 28, 2004 | 05:16 AM
cozzie4d's Avatar
cozzie4d
My plan was to get it sandblasted, like I did the exhaust manifold, which gives a nice result. But as I hear now that's maybe not a good idea.
Cleaning and painting could be a solution, only I don't know what to use to clean it and get a nice result, because there's are spots on it (= the plenum) which I think I can't clean.
Any advice on how to clean it?
Old Dec 28, 2004 | 07:21 AM
Filthy Rich's Avatar
Filthy Rich
Spilt it mate, get it bead blasted, clean every last bit of bead from it then rebuild with a new gaskett.
Did mine before painting it properly
Old Dec 28, 2004 | 07:41 AM
cozzie4d's Avatar
cozzie4d
Okay, I allready splitted the inlet into:
elbow, throttlehouse, manifold, plenum, fuelrail, injectors (greased), and fuel regulator
I'm planning to have the elbow sandblasted.
And I'm polishing the fuel rail.
So what I'll do to the inlet manifold and plenum is "bead" blast it.
After that I'll clean up the manifold/plenum before painting and re-assembling.
Thanks for the advice m8.
Sometimes I almost loose motivation in all the things I want to do to the engine parts, it's the first time ever I'm in a "rebuild-situation". But never the less, there's time enough, since I'm saving money for the new pistons and a Alcon 6-paddle
Do you have any pics of your inletmanifold (or parts of it), at the end-result?
Old Dec 28, 2004 | 09:07 AM
wimwerf's Avatar
wimwerf
and what about big brakes cris....you need them with 375+bhp...
Old Dec 28, 2004 | 09:46 AM
cozzie4d's Avatar
cozzie4d
not yet, first pistons, alcon 6-paddle, gaskets, ARP stuff and some other accessoires, then easily drive-in the engine. Do some rust threatment. rearbeam )-;
And in a one and a half year the new turbo, intercooler, injectors and probably bigger brakes
It's too bad the human body needs food, would have saved ya lot's of money
Old Dec 28, 2004 | 01:50 PM
Filthy Rich
Best i can find for now m8
Old Dec 28, 2004 | 04:57 PM
cozzie4d's Avatar
cozzie4d
Looking good, although I'm going for silver/metalcolor
Thanks for the advice again.
Old Dec 29, 2004 | 10:55 AM
cozzie4d's Avatar
cozzie4d
Hi Rich,
can you tell me what you've done to the 3 plastic hose-attach-points on the outside of the plenum, when you blasted your plenum. I can't seem to get them of/out.
Old Dec 30, 2004 | 02:00 PM
cozzie4d's Avatar
cozzie4d
Filthy Rich,
Hi Rich,
markk
Dec 2, 2021 06:59 PM
Russ Hill
Aug 31, 2015 06:44 PM
Anutternutter
Aug 21, 2015 06:07 PM
Bailes1992
Aug 16, 2015 07:14 PM
mick pearson
Aug 9, 2015 09:19 AM
