Fiesta rst getting warm!
Hi ive got a fiesta rs turbo and when its sat stood running for 2mins or so the temp guage more or less goes to the top! The car runs fine when started straight up and drove the temp stays normal also the heaters dont come reall warm do you think this is the headgasket or water pump maybe?
Wheredo you recomend buying and headgaskey/water pump from and if its the head gasket should i fit a steel one?
Thanks lpeet
Thanks lpeet
ive now changed the thermostat for a new 82degree one and all works fine now, i put the old one in some boiling water on the cooker lol and it took ages to open it didnt look to clever either, so a job well done!
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
