mk1 focus rs help on getting 300+ bhp
hi my mate has just got a mk1 frs ..mint 50.000 miles ....it has got a bluefin chip ,mongoose full exhaust ,stage 2 induction ...and is been dynoed at just under 280bhp ....300 torque ...he is toying with getting it to about 300bhp or just over ...will he need a a new turbo or what over mods will be needed ...i.e will the cluch and gearbox handle that .matt
the AP organic can take much more than that and still easy to live with feels just like the standard clutch.
some people say the standard turbo will do that power but your best talking to your tuner about it.
How many miles hard driving would you estimate then?
standard clutch wil be ok not if you keep launching it tho!you will need a hybrid turbo(contact johnfrs)on the rsoc in the focus bit!need to get rid of the cat as well if you have not all ready!also ask about tunafish on there!itsa very good software!mate of mine has these fited and his focus made 338bhp and nearly 370lbf of torque
can not remember the name of one of the manifolds but they are restrictive to around 300 bhp think its the original tubular one that the car was ment to come with(ford took it off due to a fire during its testing period!)and put the crap one on that it comes with!but cant remember the make!!!
The rsoc is ya best bit for info on these matey
id strongly reccomend live mapping, just had my mk 1 frs live mapped and i was over the moon with the results. in my oppinion bluefin is good but its a pre programmed file that might not be right for what the car needs
my mods are
full scorpion stainless including decat
k&n panel filter
pro alloy charge cooler radiator upgrade
collins cast tubular manifold
gt28 turbo - good for 350bhp easily, i went for this after i blew the gt 25
dump valve
custom map to squeeze every last bit of power out of the mods
i got 275bhp at 1.1psi, i was expecting more but he diddnt wanna set the boost to high, he recommended a boost controller so i can tweak the boost as i like, and said i will gain easily over 300bhp with another 1-2psi
running 300bhp on standard turbo will be a bit stressfull for it, thats why i went for a gt28 after i blew mine
my mods are
k&n panel filter
dump valve
my mods are
k&n panel filter
dump valve
my mods are
k&n panel filter
dump valve
no mate, any t2 flanged turbo will fit the FRS. You have differernt compressor wheels such as 60mm, 71 or 76mm, then different exhaust housings such as 0.64 and 0.86 AR Any of these can be GT28's. Yours is probably a GT2860 with a 0.64 rear.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
