cosworth uprated breather
Old Oct 17, 2009 | 09:04 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Default cosworth uprated breather
could anyone expain what pipe goes to where
cheers
Old Oct 17, 2009 | 09:05 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
Well what breather do you have and what pipe are you confused about?
Does the breather have 2 tanks or just the one?
Old Oct 17, 2009 | 09:09 PM
ASHCOSSIE's Avatar
ASHCOSSIE
not sure of the make but the bottom pipe is about 1 inch in diameter and was told this runs to atmosphere, but i thought the should be a return to the sump, just a bit confused about the 4x4 sump on o/s has what looks like a oil return from the flame trap standard oil breather and i would have thought the large return on uprated breather should run to this
cheers
fuzzy's Avatar
fuzzy
14000+ post superhero
mine has 4 pipes. 1 from the rocker cover into the top of the breather, 1 from around the middle of the block under the inlet manifod to the middle of the breather, 1 to drain back to the sump from the bottom of the breather and 1 as a vent from the middle of the breather to atmosphere with a small filter on the end. you can see it at the top of this pic....
Old Oct 17, 2009 | 09:11 PM
Ebonycossie4x4
cheers
some people vent the bottom into atmosphere and some put it back into the sump...
My escort one was into the sump i beleive but my first ever saff had just a bailey breather and that was into the atmosphere.
Old Oct 17, 2009 | 09:13 PM
fuzzy's Avatar
fuzzy
surely the bottom pipe should go to a catch tank or return back to the sump? fumes and gases would escape from the top with the oil running to the bottom?
on my pic the single pipe to the front is the vent.
Ebonycossie4x4
as you only have one tank its fairly the simple. Fuzzys looks different Poss a bit home made, Still good never the less.
If its a bailey i thought it only had 3 pipes. 1 to rocker one to kidneybox at side of engine and one to sump or atmosphere.
I could be wrong though so someone else needs to confirm
Old Oct 17, 2009 | 09:14 PM
Ebonycossie4x4
But no massive quantity of oil actually goes through the breather...
I would always go back to the sump but i have seen people that havnt lol..
I dont recommend it though!
Old Oct 17, 2009 | 09:16 PM
ASHCOSSIE's Avatar
ASHCOSSIE
surely with 3 pipes one from rocker cover, one from kidney box and one back to sump it couldnt breath any way surely the system would pressurise
cheers
Old Oct 17, 2009 | 09:20 PM
Ebonycossie4x4
i suppose mate...
I dunno ive heard so many different things about cosworth breathers i give up lol.
I would just get my tuner to put it on anyway.
Old Oct 17, 2009 | 09:41 PM
RS03 PAT's Avatar
RS03 PAT
as above but the fourth and slightly smaller diameter one goes to the bottom of the block on the turbo side. With the Bailey kit you get a replacment adaptor that screws into the block once the origional blanking plug has been removed. been a while since i fitted one but i think this is right!
Old Oct 17, 2009 | 10:04 PM
FletchCossie's Avatar
FletchCossie
On a Bailey mirror image breather tank there is 4 pipes. One to kidney box, one to cam cover, one to turbo side hole (Adaptor supplied) and one towards the floor for vent to atmosphere.
Old Oct 17, 2009 | 10:48 PM
J1mbo's Avatar
J1mbo
B1mbo
get a pic of your breather up first so rather than guessing we know what were looking at,
a breather in the rocker cover isnt necessary, we end up welding all of them up !
one from the back of the block turbo side to tank, one from kidney can to tank, one from tank to sump and one to atmosphere,
as above though, show us a pic and its much easier as they all varey a little
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
kevin36
Sep 2, 2015 06:24 PM
