XR3i EFi relays
Old Oct 17, 2009 | 07:11 PM
mentalasanything's Avatar
mentalasanything
Default XR3i EFi relays
Gents,
I wonder if anyone could help me, I'm after some part numbers from relays under the dash of an XR3i EFi.
I'm after the long numbers e.g. 93BG14N089BA from the top of the yellow fuel pump and red fuel injection relays. I have the finis codes but I'm trying to find them on thE-bay and all relays seem to be advertised with the numbers from the top as above.
Any help appreciated!
Lee
Old Oct 18, 2009 | 09:02 AM
mentalasanything
Anyone? They're most likely to be the same as other EEC-IV models....
Old Oct 18, 2009 | 07:11 PM
Unless you are going BUFTY ?, they are just bog std type relays ie type a or b, 4 and 5 pin.
Just write the numbers they have on the bottom, and pm me, they are about £1.50 each.
Old Oct 18, 2009 | 08:11 PM
mentalasanything
The problem is, I dont have any to know what numbers they have on the bottom. Basically I'm fitting a '3i EFi loom to my S2 and dont have the relays. Lee
Old Oct 18, 2009 | 11:06 PM
Toe Knee's Avatar
Toe Knee
Red relay
85BG6911AA
V23134-k6-x42
12V 40A
Yellow relay
81AG14N089CA
V23134-K6-X38
12V 40A
If you need anything else let me know
Old Oct 19, 2009 | 06:25 AM
mentalasanything
Top man! Much appreciated. Lee
Old Oct 19, 2009 | 06:44 PM
Toe Knee's Avatar
Toe Knee
No worries, i did an efi conversion on the gfs mfi cabby over a year ago, never again the loom i had fitted from a breakers had loads of problems that eventually got fixed but took time to find what wires were a problems etc!!
Old Oct 19, 2009 | 09:32 PM
mentalasanything
Dont talk to me about bad wiring!! I've just stripped 2 XR3i EFi looms and started to make 1 good loom. Just a few solder joins to go and the testing can begin.... Although, it is a good excuse to use my new multi-meter
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
IainRS1700T
Sep 25, 2015 06:44 AM
