zetec e piston rings
Old Oct 17, 2009 | 01:00 PM
fiestamk2's Avatar
fiestamk2
Default zetec e piston rings
i want to change the piston rings in my 2litre fiesta as there worn what is the nxt stage of rings i should go for is it std rings again are they expensive to buy
Old Oct 17, 2009 | 01:15 PM
I would say the rings will be around £100 a set, you need to get the rings to suit the piston size, ie std, .25, .50 etc.
Don't forget to hone the block as well, helps the rings bed in much better.
Old Oct 17, 2009 | 01:37 PM
fiestamk2's Avatar
fiestamk2
ive had the feeler gauges out and the top compression ring with allowences is between 0.30 and 0.50 .ive just put a 0.50 and it doesnt have a drag feel i can slide it up and down.so when getting a new set off rings it wouldnt be std would it
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
SMILER258
Sep 28, 2015 09:04 AM
