General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
can any 1 help me with this??i bought the correct screws from fords but they dont fit.....has any1 got a guide on this mod please?its starting to realy pi$$ me off now
You need a rivnut gun to squeeze a threaded insert into the hole in the B pillar. Had to do exactly the same on my S2
yeah fords gave me 2 rivet type things but they are shit....so just get a rivet gun and do it that way?also the other pillar there aint holes there for the screws that they gave me..any idas on that?p.s thanks for you advise
Rivnut gun is a special tool that fits a threaded insert into a hole the same way as a rivet works but once fitted you are left with a thread that you screw the bolt in to.
I borrowed one off a mate when I did mine. Seemed daft to buy one when I was only going to use it to do that one job. Motorfactors maybe. Sure somebody will be able to advise
thank you mate...it was doing my nut right in,i was putting the screw in to the rivet and it just kept turning,i wasa 5 mins from throwing the bloody thing....now i just need to know how to fit the rear part of it as the holes just dont seam rite.
I broke the mandrel on my rivnut setter with one still to set. Googled and found a Landrover website with instructions on how to set them without the tool - it was a bit of a fiddle but it worked and was better than waiting for the replacement mandrel to arrive in the post.
hi lads thank you for your help 666 posted me some pics of how it should work,i have gone and tested and its spot on easy when you know how hey!!big thanks to 666 and oranoco for both of your inputs
just need to get one of them rivguns now
