Ford Focus Diesel Problem
Old Oct 15, 2009 | 09:44 PM
cellitstore's Avatar
cellitstore
Default Ford Focus Diesel Problem
Hi, I have a ford focus 1800 tddi w reg, done around 105,000 miles
i was driving my car and i had my gear in second rather than 1st as i was turning in a back lane. the engine cut out ( stalled) the engine would not start up again. i checked the jectors and fuel is coming out once lossend them. checked all fueses and relays , all good. i have never had any previous problems with this car before
took my car to a diagnotic centre, they rekon it is the fuel pump, also they rekon i would need to change my timing belt if i was chaging my fuel pump, this would cost my £990 for a new timing belt and fuel pump supplied and fitted. i have not done dealings with this garage before , i may get a second opinion just incases they are wrong. as i have heard that a certain sensor on the car may be the problem ???? but im unsure??
has any of you experts got any other ideas i could try plz ??
many thanks
cellitstore
Old Oct 16, 2009 | 08:59 AM
I would take it to a specific diesel specialist, the crank sensor or cam sensor can both prevent it from starting.
A fault code may be logged if this is the case.
It's extremely unlikely to be the pump, and even if it were repair is a lot cheaper, belts are a doddle to do on these as well, the price is steep imo.
Old Oct 16, 2009 | 09:50 AM
cellitstore
Hi it did goto a diesel specilists but i think i will take it to fords jennings for a 2nd opinion. it may be another £50 worth spent.
what do you rekon ?
why do you say the pump will not be the problem ?
Thanks
sean
Old Oct 16, 2009 | 11:41 AM
I can't of course gaurantee the pump isn't duff, as the car is not in front of me, but they do usually play up in a few ways first.
Ford Focus RS Parts for Sale.
Aug 18, 2015 05:25 PM
taylora1409
Aug 12, 2015 12:06 PM
