solenoid control valve[2wd cossie air filter]
Old Mar 6, 2004 | 06:04 PM
Default solenoid control valve[2wd cossie air filter]
i have recently changed my standard air filter box for a k+n cone filter,the filter has knowhere for the solenoid control valve to go [the small pipe that goes into the airbox]i can make a hole in the rubber part of the filter for it to go,but i just wondered what this pipe is for and is there anything else i can do with it,also can i fit a small breather filter onto the other pipe from the air box [the engine breather] thanx.
Old Mar 6, 2004 | 06:31 PM
PJay's Avatar
PJay
Just remove the pipe that goes from the airbox to amal valve as it's not required once a cone air filter is fitted, you can fit a small filter to the breather
Old Mar 7, 2004 | 08:43 AM
richm's Avatar
richm
if you take the amal pipe off the airbox, don't be surprised if the max boost raises slightly - the stub on the airbox where it normally connects, acts as something of a restrictor, acting in conjunction with the amal jets. It won't be hugely significant, but just be aware.
FlashRS
13
Aug 31, 2015 06:02 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
track.focus'd
Aug 12, 2015 05:53 PM
Escortdriver1
Aug 5, 2015 12:45 PM
