bleedin brakes, quick question lads
The posh are up!!!
hi, i bleed the brake system last sunday, with the handbrake on and the pedal travels very low till the car stops, my dad said i should of bleed the brakes with the handbrake off.
series 2 by the way.
thanks
thanks
As above you need the car on the ground (if the rear load compensators are fitted) to allow fluid flow to the rear cylinders. If there is no fluid coming from the rear bleed nipple/nipples with the car on the ground then you need to be looking at the compensators. The linkage is either seized or incorrectly adjusted or the compensator valve's/pistons are sticking. There 2 compensating valves, one for each circuit/side.
